Not long got a focus 1.6 tdci
NeilT
 Share
Im new to this. I have not long bought a 1.6 tdci with 70.000 miles on the clock. Is there any common issues I should look out for? And is there any maintenance I should carry out more often than most?
Link to comment
Always do regular oil changes,I change mine every4-6000 miles.
  • Like 1
Link to comment
Yep, 6k oil changes for a start.  Yearly/12k fuel filter changes as well, they seem to clog up far sooner than Ford recommend but aren't cheap.
Also remove the engine cover and check to injector seals aren't leaking as soon as possible, catching this early saves major issues down the line.
If it's a DPF model, be aware the DPF is only supposed to last 75k, so may already have been changed, or may not...
  • Like 2
Link to comment
i changed 2 dpf last week!!
  • Like 1
Link to comment
Ok thanks is there any special oil I should use? And what im I looking for around the injectors? And what sort of price would I be looking at for a new dpf or is it ok to have it removed?
Link to comment
The oil needs to be made to Ford's specification.  I use Mobil 3000 5w30, but there are a few around with the right spec.
Around the top of the injectors you're looking for black carbon deposits, and/or a 'chuffing' noise with the engine running.
New DPF is around £200 for a non-genuine part (only lasted 3 months for me! :sad: ) or £800 for a genuine one.  Removing them is illegal...but that's not to say people don't do it.
  • Like 1
Link to comment
Ok I'll keep an eye out for the carbon. And  what would recommend to do as I ant got a lot of money? And someone I worked with said something about the turbo ant really reliable
Link to comment
I think it's good practice when starting car to idle for awhile before and after your journey,don't ask why but I did read something about it being good for the turbo lol.
  • Like 1
Link to comment
Just keep an eye on how often the DPF regenerates for now (fans running after engine shut off usually indicates a regen).  If it's not often then it should be fine for now.
The turbo isn't the problem, it's the carbon in the oil that causes it to break, regular oil changes, no leaking injectors and a clear (not blocked) DPF all help to avoid turbo failure.
  • Like 1
Link to comment
Ok thanks I'm doing 35miles to and from work and the fan don't seem to stay on but when I do that odd 2-3mile and turn off the fan seems to stay on for agers though dose that mean anything? And it never smokes or anything to indicate that its doing a regen.
Link to comment
Probably just unlucky and it's trying to regen on the short journey.  It'll start again next journey though so should be fine.  Mine never smoked during regens either, not enough to see in the mirror anyway.
If you've got a laptop you could always get a modified ELM327 cable with FORscan and see if there are any DPF codes stored to give you peace of mind that it's fine.  Can also read live data with it to see how high the pressure is getting in the DPF as well.
  • Like 1
Link to comment
Ok as it ant a problem at the monent but ill keep an eye out thank you guys you have been so much help
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
