Serpentine belt squeaking noise
simone
 Share
Hi all,
My mk1 has been giving some squeaking noise in cold engine start, but then it vanishes after the engine gets properly warm (10-15 minutes), it started since this winter but now that its got a bit warmer it stops squeaking after a shorter time. A visual inspection of the belt is not showing any sign of fray or damages, and can't see any pulley misalignment when the engine is running.
My question is, does the squeaking sound relates to the belt or could it be from a pulley?
Link to comment
Mines been squeaking for well over 2 years,I just live with it until I need to change the belt.I suppose there is a risk of the pulley seizing but haven't seen any posts about it.
Link to comment
Can faulty diodes in an alternator cause noise? if so, does the alternator needs to be replaced? Have tested the alternator an it shows good voltages 14.6 V.
Link to comment
Yes I think they can produce electrical noise at least, that can manifest itself as noise coming through your Speakers when you've got the radio on
Link to comment
I hear a low whine noise at idle and when I start to accelerate it gets a bit louder (noise regulates as the engine revs gets higher or gets lower), later on I can't hear it probably due to the engine noise, but yes I also hear a whining noise when the radio is on.
can this be sign of diode fail in the alternator?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
