Fogged light
JonnWhite
Should I be worrying about this?
Not sure if you can see it, it's on the left of the reverse light
Picture won't upload from my phone ill post it when I'm at my desk
Mine does the same, provided it clears after a time then it's nothing to worry about.
It was still there when I got out of work which was about 5 hours later
Id remove the lamp and check the seal/seals where the bulb holders secure to the light itself if a bulb has been replaced recently failing that check the lense is not coming away from the rest of the light as there only bonded on so any stress or impact on the light can cause it to break away a little and let water leak in
If you have any of those silicone sachets you get in a shoe box, stick one inside the light. They soak up moisture.
Sent from the pub with a pint in the other hand.
