The General Chat forum is ONLY for threads which DO NOT fit any other category. If your thread is anything do to with a specific model, it should go in the relevant model club section
Should an impact gun with a max of 550lbs torque loosen a 32mm hub nut
Michael9
 Share
1 hour ago, stef123 said:
That'll depend on how tight that nut is and how much breakaway torque is required to shift it
I think it's 550 break torque but will check
Dez....I had it on for about 3 secs and stopped, I think I saw it just start to move but not sure, I'll try later
These Impact guns are !Removed! great though
Link to comment
Have you used a chisel to knock the nut out of the recess? By knocking that out it should come undone easy enough I used to do them with a socket and breaker bar with a piece of scaffold tube. Leverage is usually the key if that fails get a blow torch from a DIY shop and get it red hot.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
