Danerel Posted March 26, 2016 Share Posted March 26, 2016 Hey, i am going to be changing the front brake pads on a mk2 focus. Been reading that its possible to "flip" the seals if the bleed nipple isn't cracked open and the hydraulic lines clamped? Has anyone experienced this, or is the Hayne's manual being over cautious? Thanks :) Quote Link to comment Share on other sites More sharing options...
btmaldon Posted March 26, 2016 Share Posted March 26, 2016 Ive never experienced that. I have never clamped the lines. Just open the reservoir cap first. 1 Quote Link to comment Share on other sites More sharing options...
Danerel Posted March 27, 2016 Author Share Posted March 27, 2016 ok thankyou Quote Link to comment Share on other sites More sharing options...
Russ Posted March 27, 2016 Share Posted March 27, 2016 When I change pads I just open the reservoir lid and as I press the Pistons back slowly I suck some fluid out using a syringe so it doesn't overflow. 1 Quote Link to comment Share on other sites More sharing options...
Mattamoose Posted March 31, 2016 Share Posted March 31, 2016 Dont forget copper grease ! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 1, 2016 Author Share Posted April 1, 2016 Have some at the ready :) giving a go this afternoon so will give an update :) Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted April 2, 2016 Share Posted April 2, 2016 I've only had this happen on Vauhalls, Fords are generally fine with pushing the pistons back without clamping the flexi hose and opening the bleed nipple. Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 3, 2016 Author Share Posted April 3, 2016 Went all good :) took my time as this was the first time I ever attempted something like this :) seem to be working all fine (he says) :) the brake fluid reservoir in a bit of a bad location for access on the 1.8tdci but managed to get a funnel and tube in there :) I took it slow winding back the pistons and all seems good!! Saved £60 not having the garage do it too :) 2 Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted April 3, 2016 Share Posted April 3, 2016 Good stuff. Good idea taking your time as it was your first attempt. Hope you remembered to put the giggling pin back through the laughing shaft after changing the pads. Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 8, 2016 Author Share Posted April 8, 2016 I also gave the callipers a coat of tartan paint and sprayed some wd40 on the brake discs just to help them be smooth ;) 1 Quote Link to comment Share on other sites More sharing options...
Fastlife91 Posted April 9, 2016 Share Posted April 9, 2016 NEVER EVER use wd40 on brake pads !!!!!!!!!! You were doing so well before you said you sprayed WD 40 on the damn things ! 2 Quote Link to comment Share on other sites More sharing options...
SeanW Posted April 10, 2016 Share Posted April 10, 2016 47 minutes ago, Fastlife91 said: NEVER EVER use wd40 on brake pads !!!!!!!!!! You were doing so well before you said you sprayed WD 40 on the damn things ! *can't tell if serious* 1 Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 10, 2016 Author Share Posted April 10, 2016 NEVER EVER use wd40 on brake pads !!!!!!!!!! You were doing so well before you said you sprayed WD 40 on the damn things ! My mpg has gone up considerably not having to stop all the time though? :O ;) Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 10, 2016 Share Posted April 10, 2016 Shame the front end is a little battered now though, right? 1 Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 10, 2016 Author Share Posted April 10, 2016 It's fine, that's why it's a front bumper ;) 2 Quote Link to comment Share on other sites More sharing options...
theredfox Posted April 12, 2016 Share Posted April 12, 2016 did you use coppa slip on back of pads Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 12, 2016 Share Posted April 12, 2016 48 minutes ago, theredfox said: did you use coppa slip on back of pads It's better on the front lol Quote Link to comment Share on other sites More sharing options...
Danerel Posted April 15, 2016 Author Share Posted April 15, 2016 did you use coppa slip on back of pads I did indeed :) Quote Link to comment Share on other sites More sharing options...
