Mick J Posted March 30, 2016 Share Posted March 30, 2016 Looking over the back of the engine I noticed this hose and the oil that is making a mess over the hose and metal under the map sensor hose (I have the Haynes out). I have managed to tighten the jubilee clip slightly. Not knowing much about these things, is there anything I should be looking for or concerned about. Thanks Quote Link to comment Share on other sites More sharing options...
Povo Posted March 30, 2016 Share Posted March 30, 2016 Remove the clips and take out the hose. Clean it up and look for any kind of tears in this. This exact hose is renowned for having splits and leaking boost. It looks way too dirty to be leaking just from the clip area. You should be able to buy a new hose easily for cheap! 1 Quote Link to comment Share on other sites More sharing options...
ippy Posted March 30, 2016 Share Posted March 30, 2016 Is it pushed on properly there looks like a bit of a gap 1 Quote Link to comment Share on other sites More sharing options...
salsheikh Posted March 31, 2016 Share Posted March 31, 2016 its probably old and past its best. i replaced mine with a silicon hose from viper performance hoses 1 Quote Link to comment Share on other sites More sharing options...
Mick J Posted March 31, 2016 Author Share Posted March 31, 2016 Thanks for the advice, Povo, ippy & salsheikh. I reseated and cleaned the oily end of the hose, unable to see any splits if there are any, other end of hose jubilee clip screw is under the hose unable to reach just now. Will replace hose with new and new clips. Should I be looking to replace the front hose as well ? - looks a more difficult manoeuvre ! Quote Link to comment Share on other sites More sharing options...
salsheikh Posted March 31, 2016 Share Posted March 31, 2016 when i replaced mine it cost about £20 but the front one was about £90 at the time and didnt have a leak so i left it. definately use good branded clips when replacing them. too many poorly made ones that snap if overtightened a little.... Quote Link to comment Share on other sites More sharing options...
Povo Posted March 31, 2016 Share Posted March 31, 2016 5 hours ago, Mick J said: Thanks for the advice, Povo, ippy & salsheikh. I reseated and cleaned the oily end of the hose, unable to see any splits if there are any, other end of hose jubilee clip screw is under the hose unable to reach just now. Will replace hose with new and new clips. Should I be looking to replace the front hose as well ? - looks a more difficult manoeuvre ! No just replace this one that has the leak. Generally this one causes most trouble. The others are usually fine. It's because the 90 degree hose is near the EGR and is very hot from exhaust gasses going through the EGR. 1 Quote Link to comment Share on other sites More sharing options...
