Speeddemon Posted April 3, 2016 Share Posted April 3, 2016 Hi I have a ford Focus 2005 1.6 auto mark 2 the reverse light is not working I was told it was a switch but I can find one one there any where. So can some help me to locate a sensir/switch or relay fuse that might be broke and how I can fix it thanks Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 4, 2016 Share Posted April 4, 2016 reverse sensor is on the gearbox Quote Link to comment Share on other sites More sharing options...
iantt Posted April 4, 2016 Share Posted April 4, 2016 reverse lights are operated via a relay and triggers the relay via the transmission control module, no external switch. i take it you have checked bulb, bulb holder and if there is a 12v feed and earth at connector for bulb holder? Quote Link to comment Share on other sites More sharing options...
ippy Posted April 4, 2016 Share Posted April 4, 2016 i had this problem a while ago and before i started buying switches and stuff i took the light to pieces and give it a good clean cos you get a lot of crud in there put it all back together and hey presto it worked, check all the wires especialy the earth iantt and Stoney871 2 Quote Link to comment Share on other sites More sharing options...
Speeddemon Posted April 4, 2016 Author Share Posted April 4, 2016 I need to take the bulb holder off clean it and the wires going to I know you say it worked by the relay how do I know if the relay as broke I never thought of the above just switches thsnks Quote Link to comment Share on other sites More sharing options...
iantt Posted April 4, 2016 Share Posted April 4, 2016 theres also 2 fuses in the circuit to check, think the relay is the one in the engine bay fuse box, you will see the big fuses at the back, to the right of those fuses there are 2 relays 1 below each other. its the lower one, you could swap that for another one the same in the fusebox, if you have multi meter you could do feed checks at the relay socket Quote Link to comment Share on other sites More sharing options...
Speeddemon Posted April 5, 2016 Author Share Posted April 5, 2016 i know where the the relay is but what number fuse is it i might as well buy a new relay bulb holder bulb and fuse then it should work lol Quote Link to comment Share on other sites More sharing options...
Speeddemon Posted April 5, 2016 Author Share Posted April 5, 2016 also any one got a fuse diagram so i know what fuses are what for my car ford Focus 2005 automatic Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 5, 2016 Share Posted April 5, 2016 Follow the guides link under my posts when viewed on a PC. I have a PDF fuse layout for the mk2 Focus there. Sent from my SM-G930F iantt 1 Quote Link to comment Share on other sites More sharing options...
ippy Posted April 5, 2016 Share Posted April 5, 2016 11 hours ago, Speeddemon said: also any one got a fuse diagram so i know what fuses are what for my car ford focus 2005 automatic does it not tell you in the fuse cover? Quote Link to comment Share on other sites More sharing options...
Speeddemon Posted April 6, 2016 Author Share Posted April 6, 2016 Thanks for all your help stupid ne did not check the fuses under the glove box and it was the very last on the fuse box lol thanks all working now bought a new reverse light holder and bulb to be on the safe side thanks iantt and Stoney871 2 Quote Link to comment Share on other sites More sharing options...
ippy Posted April 6, 2016 Share Posted April 6, 2016 Glad you got it sorted m8, Stoney871 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 6, 2016 Share Posted April 6, 2016 I recommend changing fuses for the blow & glow types. They have a small LED on them that illuminates if the fuse pops. Far easier to spot duff ones. http://pages.ebay.com/link/?nav=item.view&id=111846681847&alt=web Sent from my SM-G930F iantt, james1089 and ippy 3 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 6, 2016 Share Posted April 6, 2016 why cant car makers fit those when they build them!! Stoney871 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 6, 2016 Share Posted April 6, 2016 Because we'd have nothing left to mod 🤗 Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
