Deano_liv Posted April 4, 2016 Share Posted April 4, 2016 Hi, I was wondering if anyone can help, my Fiesta Zetec S tdci is in limp mode and stating Engine System Fault. Ive had my friend plug his diagnosis equipment in to get a clearer picture of the problem and it has pulled up "Glowplug Circuit A Malfunction". Ive changed the glowplug relay today hoping this will be the issue but ive had no joy. I was wondering whether the fault would clear its self once fixed or will it need to be plugged back in to clear it? Also if the relay is not the issue whats the next step I should take? I'm hoping its not the actual glowplug as ive been told they have a tendency to snap! Thanks for any help, Dean Quote Link to comment Share on other sites More sharing options...
Russ Posted April 4, 2016 Share Posted April 4, 2016 Sounds like you need to clear the code. Quote Link to comment Share on other sites More sharing options...
iantt Posted April 4, 2016 Share Posted April 4, 2016 did you test the relay wiring before coming to the conclusion of relay? Quote Link to comment Share on other sites More sharing options...
Deano_liv Posted April 4, 2016 Author Share Posted April 4, 2016 no I never tested the wiring, just knew the relay was one of the options and for 13 pound thought I would give it a try first Quote Link to comment Share on other sites More sharing options...
iantt Posted April 4, 2016 Share Posted April 4, 2016 ok, how many pins on the glowplug relay? and have you got a multimeter? Quote Link to comment Share on other sites More sharing options...
Deano_liv Posted April 7, 2016 Author Share Posted April 7, 2016 hey, sorry for the delay, just to let anyone who reads this know it ended up been the actual glowplugs. Luckily they came out without issue, lubed up the plugs, then heated up the engine, took my time and carried on lubing up the plugs as I went and they came out fine. Soon as the plugs were changed the car was perfect Quote Link to comment Share on other sites More sharing options...
iantt Posted April 7, 2016 Share Posted April 7, 2016 Thanks for letting us know, good to hear you got them out ok, I did some last week and first 3 came out easy enough, number 1 cyl was tight all the way out, I had everything crossed hoping it didnt snap. I was lucky this time. Quote Link to comment Share on other sites More sharing options...
James Peter harvey Posted July 23, 2019 Share Posted July 23, 2019 On 4/4/2016 at 11:07 PM, Deano_liv said: no I never tested the wiring, just knew the relay was one of the options and for 13 pound thought I would give it a try first Hi where is the relay on the fiesta? 2006 mine is Quote Link to comment Share on other sites More sharing options...
Mark Braithwaite Posted February 5, 2022 Share Posted February 5, 2022 WEre is the glow plug relay on a fiesta mk7 tdci 1.6 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 5, 2022 Share Posted February 5, 2022 3 hours ago, Mark Braithwaite said: WEre is the glow plug relay on a fiesta mk7 tdci 1.6 According to the owners manual it's in the engine bay fusebox. Quote Link to comment Share on other sites More sharing options...
