Stevie w Posted April 5, 2016 Share Posted April 5, 2016 Hi all I've bought a 51 plate puma ive been informed that the engine light is on because it's running LEAN any ideas what the problem is ? Quote Link to comment Share on other sites More sharing options...
dsayer Posted April 6, 2016 Share Posted April 6, 2016 Hi does this car have a secondary air pump if so that could be your problem Quote Link to comment Share on other sites More sharing options...
Stevie w Posted April 7, 2016 Author Share Posted April 7, 2016 Where will that be situated? the car drives really well just the light is on I've taken it off but after 5 days off it came back on Quote Link to comment Share on other sites More sharing options...
dsayer Posted April 7, 2016 Share Posted April 7, 2016 I'm not sure on a puma if it has one what is the code you are getting I have a galaxy and when I plugged it in I could see it was always running in open loop lean which was down to the pump not running its there to heat the cat up quicker and because it was not seen to be running left the car in open loop all the time and putting the engine light on Quote Link to comment Share on other sites More sharing options...
Stevie w Posted April 7, 2016 Author Share Posted April 7, 2016 I have been informed it's the Lambda sensor but then I've also been told about someone who changed that and still the light stayed on Quote Link to comment Share on other sites More sharing options...
dsayer Posted April 7, 2016 Share Posted April 7, 2016 Well you have 2 choices replace the sensor of buy a scanner to get the code very cheap on ebay Quote Link to comment Share on other sites More sharing options...
