runaround Posted April 6, 2016 Share Posted April 6, 2016 Hi allfirst time user looking for any help or advice re Ford Focus comms pack head unit.I have a Ford Focus 1.8Tdci Zetec facelift model with the standard radio head unit installed no bluetooth. My daughter has got 2009 titanium Focus with the comms pack head unit but she gas taken it out and installed an after market unit (not Ford)What I need to know is will the comms pack head unit out of my daughters car work in my Zetec if so what extra equipment and parts will I need to make it work in mine.any help or info would be very gratefully received. thanks in advance.attached are the 2 images of the head units, the 2nd is mine and the 1st is my daughters comms pack head unit. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 6, 2016 Share Posted April 6, 2016 depending on the aerial connector in use (as thats a standard 6000CD, you probably will not have DAB, and you wont have GPS) so these wont work. Beyond that though, probably FM / AM radio will work spot on, and you could get an external GPS for it? Quote Link to comment Share on other sites More sharing options...
runaround Posted April 7, 2016 Author Share Posted April 7, 2016 17 hours ago, jeebowhite said: depending on the aerial connector in use (as thats a standard 6000CD, you probably will not have DAB, and you wont have GPS) so these wont work. Beyond that though, probably FM / AM radio will work spot on, and you could get an external GPS for it? thanks Jee would I be able to get the bluetooth working for hands free calls Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 7, 2016 Share Posted April 7, 2016 You would then need to add in a bluetooth module and enable it on the gem board I believe, but it should be feasible. Quote Link to comment Share on other sites More sharing options...
runaround Posted April 7, 2016 Author Share Posted April 7, 2016 7 hours ago, jeebowhite said: You would then need to add in a bluetooth module and enable it on the gem board I believe, but it should be feasible. sorry to be a noob Jee but you wouldn't know what bluetooth module I would need and sorry to be a noob again but what is a gem board and how would I enable it Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 8, 2016 Share Posted April 8, 2016 For the bluetooth module I don't recall but it is on the forum somewhere. As for the gem board it's the fuse box under the glove box Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 8, 2016 Share Posted April 8, 2016 Also you would need steering wheel controls and some software to enable it. Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
runaround Posted April 8, 2016 Author Share Posted April 8, 2016 3 hours ago, jeebowhite said: Also you would need steering wheel controls and some software to enable it. Sent from my GT-I9195 using Tapatalk thanks Jee fitted the unit the other day and it works on radio and cd the steering wheel control stick works too i.e. volume/mode/track got the satnav sd card / gps Ariel and mic. just need the bluetooth module and then have a go at installing it all, thanks for your help will let you know how I get on when I get the bits. will look on the forum for which bluetooth module i need jeebowhite 1 Quote Link to comment Share on other sites More sharing options...
