ff2007 Posted April 8, 2016 Share Posted April 8, 2016 Hi all, Specs says Automatic transmission fluid (including cooler and tubes) takes 8.9 liters. How much oil should be put in after draining the old oil? Should it be the same amount of the drained oil including the oil that was in the filter itself? Thanks! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 8, 2016 Share Posted April 8, 2016 depending on the box, and given I am no expert at this, it depends where the filler is. If the filler is just off the gearbox, the general advice can be to run it up to overflowing point, but you should consult something like a haynes manual. sonic113 1 Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 8, 2016 Author Share Posted April 8, 2016 This haynes manual does not cover CVT, Powershift or automatic transmission! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 9, 2016 Share Posted April 9, 2016 Clearly I overlooked that. Drop me a pm as a reminder, I have the workshop manuals at home and will see if I can dig it out for you, I will most likely forget after I add this post, so definitely send me the reminder. Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Incontro Posted April 9, 2016 Share Posted April 9, 2016 On 4/8/2016 at 0:18 PM, ff2007 said: Hi all, Specs says Automatic transmission fluid (including cooler and tubes) takes 8.9 liters. How much oil should be put in after draining the old oil? Should it be the same amount of the drained oil including the oil that was in the filter itself? Thanks! At how many miles/years does auto transmission fluid need to be changed? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 9, 2016 Share Posted April 9, 2016 Technically I don't believe there was or is a maintenance schedule for it Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 9, 2016 Author Share Posted April 9, 2016 I've read, it said every 70k km. Not sure if there is a way to check its level of oil?? I think the only way to find out is to drain it and see how much comes out. I saw some videos that rotating the wheels helps with the drain. Anyone has insights on this? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 9, 2016 Share Posted April 9, 2016 OK so just looking at the workshop manuals, basically, remove the allen key overflow plug, and drain, then fill until it overflows. resecure and jobs a good 'un ff2007, sonic113 and iantt 3 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 9, 2016 Share Posted April 9, 2016 the drain plug is the level plug also , filler plug is higher up the box. ff2007 1 Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 10, 2016 Author Share Posted April 10, 2016 Is this the right process in sequence? As far as I read there are three plugs involved in this process. Remove the fluid filler plug Remove the fluid drain plug (at this moment oil should come out, what about the oil which is in the filter?) Install the fluid drain plug Remove the fluid overflow plug using an Allen key (is this installed in the fluid drain plug itself?) Fill the transmission with transmission fluid until the fluid escapes from the overflow Install the fluid overflow plug using an Allen key Install the fuel filler plug Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 10, 2016 Share Posted April 10, 2016 Tonight I will get onto etis, print the instructions to some form of document and send it to you Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 10, 2016 Author Share Posted April 10, 2016 There is very limited information on what this Main Pressure Sensor in TCM really does, it says it measures the main pressure in the system, it doesn't tell what are its operating conditions that should be met, etc. In this case pressure is derived from the amount of oil in the gearbox. This makes one think it should be a low pressure from low oil while engine is cold and once it warms up, the pressure is regulated by expanding the oil. Does this make sense? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 10, 2016 Share Posted April 10, 2016 Agree it certainly seems a sensible conclusion Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 10, 2016 Share Posted April 10, 2016 I just happened to find these on the internet... All you need to check, drain and refill the system... ff2007, Stoney871 and iantt 3 Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 11, 2016 Author Share Posted April 11, 2016 Checked the transmission oil, color was green and its level was good! If these conditions are met and good, is it still possible that TCM is the issue? Or ABS/ESP module? It's strange how this issue is depending on temperature or maybe pressure?? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 12, 2016 Share Posted April 12, 2016 To be honest it's worth still doing a change, green may be good but draining it will tell you if there are any fragments which should not be present. Tcm could be an issue but if it's a durashift then there are suggestions here on how to resolve it. Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
ff2007 Posted April 12, 2016 Author Share Posted April 12, 2016 Thanks James! Not sure if this could be from a pressurized system perhaps in the Crankcase Breather? Blocked EGR ventil?! Here is the detailed thread on this Quote Link to comment Share on other sites More sharing options...
