runaround Posted April 9, 2016 Share Posted April 9, 2016 I need a bluetooth module Can anyone tell me if I have to order a bluetooth module to match the car model, or the head unit model thanks images of car and head unit below Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted April 9, 2016 Share Posted April 9, 2016 I have the Nokia bluetooth module still in my car not taken it out yet, as I upgraded my stereo it's not in use. I have a 2010 Focus with the Sony head unit/dab so see if my one will work in yours, it's the one behind the glove box? If it works then PM me and we can talk prices Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
runaround Posted April 9, 2016 Author Share Posted April 9, 2016 12 minutes ago, sean.kerwin said: I have the Nokia Bluetooth module still in my car not taken it out yet, as I upgraded my stereo it's not in use. I have a 2010 Focus with the Sony head unit/dab so see if my one will work in yours, it's the one behind the glove box? If it works then PM me and we can talk prices Sent from my iPhone using Tapatalk I am a bit of a noob with these things, I don't know if it would work, I had the standard 6000CD unit in my car (no bluetooth) Focus 1.8 tdci Zetec the unit I have now is from my daughters car 2009 Focus Titanium see images above, would I just plug the module into the back of the head unit Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted April 9, 2016 Share Posted April 9, 2016 The bluetooth module is under the glove box. Somewhere.... I need to find it. You have to remove the glove box and see if the wiring is there to connect it to your loom. It'll be taped up behind it with a plug on the end. I'll have a look later to see if I can easily remove mine. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
runaround Posted April 9, 2016 Author Share Posted April 9, 2016 19 minutes ago, sean.kerwin said: The Bluetooth module is under the glove box. Somewhere.... I need to find it. You have to remove the glove box and see if the wiring is there to connect it to your loom. It'll be taped up behind it with a plug on the end. I'll have a look later to see if I can easily remove mine. Sent from my iPhone using Tapatalk thanks, my Zetec wont have a BT loom so would need the wiring to go from the module to the back of the head unit I presume Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted April 9, 2016 Share Posted April 9, 2016 I think the loom will be the same in every car. Because the bluetooth goes into the block that goes into the headunit. It's not a separate connection: Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
