paul hands Posted April 9, 2016 Share Posted April 9, 2016 Any help to figure out why it won't start would be really appreciated,worked fine the night before and now nothing,plus digital temp just comes up with lines across now ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Russ Posted April 9, 2016 Share Posted April 9, 2016 Does it attempt to turn over at all? instrument cluster faulty maybe? Would disconnecting the battery for an hour clear the codes and let it start? Quote Link to comment Share on other sites More sharing options...
paul hands Posted April 20, 2016 Author Share Posted April 20, 2016 No wont attempt to even turn over iv cleared the codes with my f super but come straight back on,could this be outside temp sensor? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
paul hands Posted April 24, 2016 Author Share Posted April 24, 2016 Turned out to be an engine fuse box relay Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
bbdamix Posted May 17, 2016 Share Posted May 17, 2016 Can u please describe the reley position/number/color? I have exactly same problem with my mondeo mk3 2003 1.8 gasoline 81kw. Engine won't crank,not a sound. My odometer and temp display is showing normal,but after a few seconds is showing dashes -----. I already checked fuses but nothing wrong. If i manualy engage the starter relay,the engine crank,but not start. Immo led is off after turning the key. Strange one: if i disconnect the cable from the ecu/pcm, there is no change,as if the ecu isn't there. Possible ecu is dead??? Thank you Quote Link to comment Share on other sites More sharing options...
bbdamix Posted May 18, 2016 Share Posted May 18, 2016 Ok,i solved my problem today. My ecu is dead. I tryed with another ecu and started at first turn. Quote Link to comment Share on other sites More sharing options...
