NullaDave Posted April 11, 2016 Share Posted April 11, 2016 I recently bought a Nextbase Dash Cam and decided to hardwire it instead of using the supplied cigar lighter adapter. So I bought the Nextbase hardwire kit which uses a piggyback fuse plugged into the fuse box. The instructions suggest using a fuse that is switched live so the camera only comes on when the ignition is on. So I used the rear window heater fuse. So everything went in fine but when I plugged in the dash cam with the ignition off, it switched on and started recording and charging. I was expecting nothing to happen until I switched on the ignition. I've read a few other threads about the power staying on for about 30mins after the ignition is switched off but they all relate to the Mk2.5 onwards and not the Mk2. Does anyone know if the Mk2 has a time delayed power down or if there is a fuse I can use that is definitely switched live only? Any advice will be most appreciated. Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 11, 2016 Share Posted April 11, 2016 I used the fuse for the rear fog light Quote Link to comment Share on other sites More sharing options...
Ford Year: 2022
Ford UK Shop for genuine Ford parts & accessoriesJoin the conversation
