Markb55 Posted April 11, 2016 Share Posted April 11, 2016 Hi all I'm having timing belt kit done Wed, when I booked it in I asked for the water pump to be done as well but they told me my pump doesn't run off the timing belt, my car is a 2006, 1.6 is the garage correct. Cheers guys Quote Link to comment Share on other sites More sharing options...
iantt Posted April 11, 2016 Share Posted April 11, 2016 they are correct that the water pump does not run off the timing belt, but the timing belt tensioner fits to the pump housing so if your water pump requires replacing in the future you will need timing belt off again, therefore a new belt again. all the covers have to come off again etc. so i would advise on a waterpump being fitted so it gives you piece of mind that it should last until the next belt change GingerFlame 1 Quote Link to comment Share on other sites More sharing options...
Christianiani Posted April 11, 2016 Share Posted April 11, 2016 Hi Mark. I would agree with the garage if it's a Petrol. If you've got a 1.6 diesel though it does run off the Timing/Cam belt. Hope this helps! Quote Link to comment Share on other sites More sharing options...
Markb55 Posted April 11, 2016 Author Share Posted April 11, 2016 Cheers guys Quote Link to comment Share on other sites More sharing options...
