Ant123 Posted April 11, 2016 Share Posted April 11, 2016 I have a Ford Focus Zetec 1.6 2008 .im having a problem when I start my car the front lights flash on while I'm trying to start the car and it's draining my battery I just wondered if anybody else has had these issues and if so does any body no what the problem is and how to fix it Quote Link to comment Share on other sites More sharing options...
simcor Posted April 11, 2016 Share Posted April 11, 2016 Chances are your battery is knackered. On my ZTT I used to own flashing headlights whilst trying to start it was an indication the battery was goosed. I would not be surprised if the same applies to most cars these days. 2 Quote Link to comment Share on other sites More sharing options...
Russ Posted April 11, 2016 Share Posted April 11, 2016 Had the same problem, one new battery later and problem solved. when voltage was checked using the dashboard trick it was 11.8 volts! 1 Quote Link to comment Share on other sites More sharing options...
Ant123 Posted April 12, 2016 Author Share Posted April 12, 2016 Thanks to both of you guess it's a new battery for me then Quote Link to comment Share on other sites More sharing options...
simcor Posted April 12, 2016 Share Posted April 12, 2016 If it's on its original battery then it has lasted very well. People often forget about the condition and age of a battery being important. And usually it is winter time when the battery is most stressed and fails, people always get caught out by this in the winter. Battery should really be replaced every 4-5 years ideally in my opinion. Unless sooner because of an over or undercharging alternator etc killing the battery. 1 Quote Link to comment Share on other sites More sharing options...
richard150 Posted April 12, 2016 Share Posted April 12, 2016 don't talk to me about batteries had st , bike ,and jump starter battery go flat on me at the beginning of the year Quote Link to comment Share on other sites More sharing options...
Russ Posted April 12, 2016 Share Posted April 12, 2016 6 hours ago, Ant123 said: Thanks to both of you guess it's a new battery for me then Make sure you get a silver calcium battery and not a lead acid one. 1 Quote Link to comment Share on other sites More sharing options...
