eyeless47 Posted April 11, 2016 Share Posted April 11, 2016 Hi all I have a hose in my engine bay which has come off and seems to fit very loosely. I've already had to replace the hose once, but have forgotten what the hell the hose is for! Firstly, if you could tell me what the hose is for that would be great, also should the hose be so loose? It just sits round the plastic clip so isn't very secure at all, it has come off a couple of times and spurts plenty of oil out of it. Should the hose be this loose or should there be a clip that sits around it? Any help would be appreciated, thanks! Quote Link to comment Share on other sites More sharing options...
catmand00 Posted April 11, 2016 Share Posted April 11, 2016 That's the crankcase breather hose it should have a plastic clip around the end of it but you've obviously lost yours. It will create a right mess under the bonnet if it's not secured properly Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
eyeless47 Posted April 11, 2016 Author Share Posted April 11, 2016 I have the plastic clip on the crankcase end, but the hose just sits around it with no real fix to it. The hose wouldn't have expanded to lose suction on the clip or anything would you think? Quote Link to comment Share on other sites More sharing options...
ippy Posted April 11, 2016 Share Posted April 11, 2016 Put a jubilee clip on it, Quote Link to comment Share on other sites More sharing options...
catmand00 Posted April 11, 2016 Share Posted April 11, 2016 It's not the original hose. Where it joins the air hose it's held on with circlip on yours it's meant to be one complete piece. I would guess previous owner cut it off and might have tried to fit an oil catch can but you really need a new air hose Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
eyeless47 Posted April 11, 2016 Author Share Posted April 11, 2016 Ok thanks for the help guys Quote Link to comment Share on other sites More sharing options...
S40Un Posted April 11, 2016 Share Posted April 11, 2016 buy yourself this http://pages.ebay.com/link/?nav=item.view&alt=web&id=181923113667&globalID=EBAY-GB Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted April 12, 2016 Share Posted April 12, 2016 I found after market parts utterly crap, didn't seal properly, go to ford and get the right part. Quote Link to comment Share on other sites More sharing options...
S40Un Posted April 12, 2016 Share Posted April 12, 2016 I'd normally agree but Bought the one in the link above 10,000 miles ago no leaks , still looks as new as when I bought it. Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted April 12, 2016 Share Posted April 12, 2016 up to you, I think the ford part set me back about 20 quid, the aftermarket one was abut 15 including the large section, whilst it fit, the O-ring on mine must have been a fraction too small, the ford part worked no bother at all, I guess if it works than great, but if it doesn't, for the sake of a fiver, id go ford next time(you don't need the large section anyway unless its split) Quote Link to comment Share on other sites More sharing options...
simcor Posted April 13, 2016 Share Posted April 13, 2016 On 12/04/2016 at 8:29 PM, Dee_82 said: up to you, I think the ford part set me back about 20 quid, the aftermarket one was abut 15 including the large section, whilst it fit, the O-ring on mine must have been a fraction too small, the ford part worked no bother at all, I guess if it works than great, but if it doesn't, for the sake of a fiver, id go ford next time(you don't need the large section anyway unless its split) I went to Ford for a cost for this pipe and it was !Removed! expensive, you can't buy just the small pipe it is a one piece pipe. I bought an aftermarket one of eBay like that listing and it fits perfectly. IIRC the Ford part was £70 odd quid which I thought was ridiculous. S40Un 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2016 Share Posted April 13, 2016 lucky you all havent got a later Focus 1.6, you can double the £70 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted April 14, 2016 Share Posted April 14, 2016 ill check microcat but I did get that small pipe with the connector, originally I wanted the plastic connector but that wasn't sold separately. the only thing that might make this different for this hose is that this hose in the picture is the older design, ive got the newer one https://www.bing.com/images/search?q=16+tdci+air+filter+turbo+hose&view=detailv2&&id=4DE254C7C4EEDDDAF0633703C1B3DFDED6715522&selectedIndex=80&ccid=FvLPhCYu&simid=608026697010515721&thid=OIP.M16f2cf84262ed9ea2e70edf45fe5017do0&ajaxhist=0 Quote Link to comment Share on other sites More sharing options...
S40Un Posted April 15, 2016 Share Posted April 15, 2016 As above, my local ford place wouldn't sell me just the pipe either. Tried buying the 2 rubber Intercooler pipe collars that fit over the ends on the plastic Intercooler pipe on the drivers side as well. They wouidnt sell me those on their own either. Whole pipe was over £125 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted April 15, 2016 Share Posted April 15, 2016 Then I'm a lucky chap It seems, perhaps they had a nackard one sitting around, the replacement aftermarket one that apparently came from turkey was a pile of crap, it did have the two sections though, the larger section did become useful after I over tightened the ford one and it got ripped to shreds, but that little pipe with the daft plastic connector never did the job. The ford one worked fine (which came in its own little bag) after which I pulled the rubber hose off the connector and used my own silicone hose to my catch can. Quote Link to comment Share on other sites More sharing options...
