TomsFocus Posted April 14, 2016 Share Posted April 14, 2016 Hi, Just got to Nan's and locked the car no problems, left phone in there so unlocked to get it and it won't lock or unlock on the button? Locks fine manually. I can't imagine the battery has just died without warning? So is there a re sync procedure? Can't search ATM so quick answers appreciated. Cheers Tom Quote Link to comment Share on other sites More sharing options...
simcor Posted April 14, 2016 Share Posted April 14, 2016 Turn the ignition key 4 to 5 times in quick succession you should hear a beep then press button on remote hear another beep. Turn ignition off then back on then try your buttons again. You will need to do it again later with all remote keys you have if you don't have them all to hand. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 14, 2016 Author Share Posted April 14, 2016 'All remote keys'? I only have one remote and one manual. Thanks though, I'll go try it now! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 14, 2016 Author Share Posted April 14, 2016 Sorted now, that was easy lol!! Cheers Simon. Quote Link to comment Share on other sites More sharing options...
simcor Posted April 14, 2016 Share Posted April 14, 2016 52 minutes ago, TomsFocus said: 'All remote keys'? I only have one remote and one manual. Thanks though, I'll go try it now! I only say that because all remotes the car has need to be reprogrammed at the same time otherwise the others will no longer work. Cheap and easy enough to get a second flip key now with Forscan allowing PATS programming. Lol 1 Quote Link to comment Share on other sites More sharing options...
simcor Posted April 14, 2016 Share Posted April 14, 2016 3 hours ago, TomsFocus said: Sorted now, that was easy lol!! Cheers Simon. You are welcome Thomas lol 1 Quote Link to comment Share on other sites More sharing options...
