Cruise Control
MrNixon
 Share
I've seen the post about retrofitting the cruise control switch to the existing steering wheel but I've managed to find a new steering wheel with cruise control and asl already on it.
Would it just be a case of swapping steering wheels so plug and play and then doing the ECLM?
I have a 61 Plate Focus Hatchback. Registered December 2011.
Link to comment
Think you may need a small wiring harness, unless its in steering wheel already, as you need to connect the existing buttons on airbag part to it .got old wiring somewhere to show what I mean, will photo and post up. After all wired in , you need focuus software and enable it in the car configuration.
  • Like 2
Link to comment
That'll be brilliant. If you can post part numbers or photos of what else I will need that'll be a big help.
  • Like 1
Link to comment
As yours is earlier than mine, it could be the case you dont need any wiring extra. You have got the voice and volume buttons low down on steering wheel. So you just need to remove airbag and check if you have connector that matches the steering wheel with cruise.
Link to comment
21 minutes ago, iantt said:
Looks like its a straight swap then .
Does it have the connectors that's needed? So I'm guessing that all I need to do is swap the steering wheel and then modify the car config using focuus software?
Link to comment
Now I;ve been looking up prior to installing the new steering wheel. How ever What part of the clock spring do I have to tape to stop it from moving?
Link to comment
Most difficult bit is removing the airbag, unclip one side , then unclip the other side, and opposite side clips back in again.lol
Link to comment
Thats what I thought, I didn't think it would be easy. Is the laptop part easy?
Link to comment
52 minutes ago, iantt said:
23 minutes ago, iantt said:
yes, fairly straight forward, just make sure to give the car a run before hand to charge battery up , as most programming errors occour with battery voltage below 11.6v
battery disconnect is N-P reconnect is P-N right?
ill give it a run out for 30 mins before start of project.
Link to comment
forscan now has limited configuration ability, its not as in depth as ELMconfig for the Mk2 is but its got the basics most need, more important is the support you get from their forum is much better
Link to comment
I don't have the MK2, I have the MK3. :)
  • Like 1
Link to comment
yes I know, ELMconfig is for the MK2, but foscan seems to have started building up functionality across a number of cars and versions.
Link to comment
So either way, the configuration part should be easy right?
Link to comment
On 25/04/2016 at 1:30 PM, Dee_82 said:
Should be! ;)
Steering wheel in place!
What is the best ELM327 USB Connector? I bought one from eBay but it says "Can't init ELM".
Link to comment
Mk3 uses FoCCCus software. Find it at http://ford.xtlt.ru/' Also check this out to make sure you have the correct drivers for the cable http://www.totalcardiagnostics.com/support/Knowledgebase/Article/View/1/0/how-to-install-elm327-usb-cable-on-windows-and-obd2-software
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
