wjay Posted April 18, 2016 Share Posted April 18, 2016 New to the forum so forgive me if this has answers already (I have searched) .My last car was a Focus estate petrol 1.8 15 years old with low mileage that had a starting problem . once or twice a week the engine would not start , starter turned over but no ignition . This was resolved by using the flooded engine procedure but on one occasion left me stranded , no start had to use breakdown . Garage said the only thing they found was the fuel pump had no fuel in it so that was replaced . All was ok for 3 weeks then the the same problem started again . Eventually got rid and bought a 2011 petrol Zetec with only 15k on the clock , really pleased with it but after a few weeks car would not start , same symptoms as the old car , used the flooded engine routine and ok , this now happens once a week quite at random . My question I would like ask is , is this a known ford problem with a resolution or a sympton of an underlying problem that needs investigating . Any info would by appreciated as this has just taken the edge off a really good buy . Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted April 18, 2016 Share Posted April 18, 2016 On last 3 fords i have owned all newish sometimes dont start i turn the key nothing happens then turn the key again then fires in to life its quite rare but all my cars have done this. I dont know if this is the same symtoms as your car tho Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 18, 2016 Share Posted April 18, 2016 if the cars not starting it needs looked into it could be ignition barrell issue a worn key a transponder or pick up issue a sensor a fuel pump I can say from Fiesta escort Focus all the fords I've had its never happened once Quote Link to comment Share on other sites More sharing options...
