sloopy Posted October 24, 2009 Share Posted October 24, 2009 My nephew has a Puma, 1.7 petrol, manual gearbox, which has always had a SLIGHT oil leak, which has now become much worse. The oil seems to cover the back half of the sump and the leaking oil goes to the driver's side of the car, over the drive shaft and so on. If it is a drive-shaft seal, as is suspected, how difficult is the job for a reasonable-level DIY mechanic? My car is a 1962 Morris Minor on which I do all servicing and repairs, and I've done a few major jobs on my nephew's Puma-replacement door, exhaust etc. That said, I'm nowhere near skilled mechanic. best wishes Quote Link to comment Share on other sites More sharing options...
flying clutchman Posted October 27, 2009 Share Posted October 27, 2009 My nephew has a Puma, 1.7 petrol, manual gearbox, which has always had a SLIGHT oil leak, which has now become much worse.The oil seems to cover the back half of the sump and the leaking oil goes to the driver's side of the car, over the drive shaft and so on. If it is a drive-shaft seal, as is suspected, how difficult is the job for a reasonable-level DIY mechanic? My car is a 1962 Morris Minor on which I do all servicing and repairs, and I've done a few major jobs on my nephew's Puma-replacement door, exhaust etc. That said, I'm nowhere near skilled mechanic. best wishes Quote Link to comment Share on other sites More sharing options...
flying clutchman Posted October 27, 2009 Share Posted October 27, 2009 My nephew has a Puma, 1.7 petrol, manual gearbox, which has always had a SLIGHT oil leak, which has now become much worse.The oil seems to cover the back half of the sump and the leaking oil goes to the driver's side of the car, over the drive shaft and so on. If it is a drive-shaft seal, as is suspected, how difficult is the job for a reasonable-level DIY mechanic? My car is a 1962 Morris Minor on which I do all servicing and repairs, and I've done a few major jobs on my nephew's Puma-replacement door, exhaust etc. That said, I'm nowhere near skilled mechanic. best wishes Changing the oil seal is not too difficult but are you sure that's what it is? Try and decide if it's gearbox or engine oil.Gear oil smells very different, sweet and sickly. If it is gear oil that's leaking you need to attend to it or you'll find the gearbox empty of oil. Goodbye gearbox. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 24, 2010 Share Posted February 24, 2010 Changing the oil seal is not too difficult but are you sure that's what it is? Try and decide if it's gearbox or engine oil.Gear oil smells very different, sweet and sickly. If it is gear oil that's leaking you need to attend to it or you'll find the gearbox empty of oil. Goodbye gearbox. i agree oil has a tendency to get everywhere it may look like thats where its coming from but while driving the winds blowing it in all directions best to clean the area up and check Quote Link to comment Share on other sites More sharing options...
Marco87 Posted December 18, 2019 Share Posted December 18, 2019 On 10/27/2009 at 6:56 PM, flying clutchman said: Changing the oil seal is not too difficult but are you sure that's what it is? Try and decide if it's gearbox or engine oil.Gear oil smells very different, sweet and sickly. If it is gear oil that's leaking you need to attend to it or you'll find the gearbox empty of oil. Goodbye gearbox. Hi, I am having the same issue and it is defiantly the drive shaft seal. Can you explain how to remove the seal to replace please Quote Link to comment Share on other sites More sharing options...
