Making my Focus sound a bit more 'Throaty'
JoshyBoy96
 Share
Hi all, this is my first experience of an online forum so I'm pretty new to all this!
I have a Focus mk2 1.6 TDCi (remapped) and I love it, however, I would like to make it sound just a little bit more 'throaty' when my heavy right foot hits the floor.
I'm not wanting to spend a lot, like maybe around £50-£60, and I don't want it to sound like a chav in his little 1.0 litre Corsa who has put a screwdriver through the Cat, I just want a little more of a growl as I'm pulling away.
What are my best options?? Will I need to splash out on a full induction kit, or are there cheaper methods?
Cheers
Link to comment
how about completely free ?
removing the snorkel  ( the plastic air splitter pipe behind the front grill that flows into the airbox ) will improve the engine note without being loud & irritating and wont cost a dime.........
Link to comment
Even better! I will have a look as soon as I'm back from work tomorrow. Is the snorkel below the airbox? and what is the best way of getting to it? (I'm a bit of an amateur with this so it will be trial and error for me otherwise) haha
Thanks for the help though!
Link to comment
So I had my car in pieces yesterday trying to find this snorkel.... I thought that it would be located in front of the radiator but I couldn't locate it at all.... Any thoughts?
Also, if mine isn't there, are there any other ways of making it sound a little better?
Link to comment
Its not on there, so there is a plastic tube that comes from the airbox then goes in to a second tube that runs along the gap at the front, it has a dent in it that allows it to pass under the bonnet lock and terminate the other side with an upward facing hole.  if you haven't removed it, then someone already has
Link to comment
Ah right... Thanks for clearing that up, it explains a lot! Haha
So is there another way I can make it sound a bit more beefy without spending a lot? Or am I best just leaving it alone?
Link to comment
simple induction filter would be the easiest way if routed to just begin the headlight with a heat shield it will be fine then simply route a cold air feed from lower grill to it other than that its time to look at the exhaust
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
