engine malfunction
mrmetallica
 Share
started getting this the other day.thought it was the plug in the passenger foot well .when i play with the wires it seems to go of,is it coincidnce or is it the wire ?cant seem to see anything.
well ive got the elm cable and a focom cable but the focom software isnt installing properly . is focom compatible with windows 10 ?
any one help need to sort this out not sure where to try next.
Link to comment
sounds like the dash cluster or dash cluster wiring no idea why but suddenly this year I've seen a spate of them its easy to tell with the car running undo the 2 screws holding the cluster in place remove cluster but keep multiplug attatched and wiggle the wires you'll suddenly get a malfunction message restarting the car will clear it you'll also get high speed can faults the most common place for the wiring is where its clipped in with a metal clip the wiring seems to break there
Link to comment
when i play with the wires on the passenger side lower plug it goes of not sure if its coincidence or not .i cant see anything wrong with the wires .
got these codes coming up. any ideas what they are ? been looking all day no real answers.
cleared them all will see how it goes
U2023 Fault Received From External Node
U2202 Invalid Configuration Data Received
C1278 STEERING Wheel Angle 1and 2 Signal Faulted -
U1900 CAN Communication Bus Fault - Receive Error
U2012 Communication Bus Error (Non SCP)
C1446 Faulty brake switch circuit: Open or short circuit
U2510 CAN - Invalid data for Vehicle Security.
Link to comment
just been out in the car and it pulled great and drove great.
if the codes are left in the car will it still sound alarm warnings ?
hopefully its ok
Link to comment
its the cluster or wires the u codes high speed can suggest this you'll find after so many cycles of the ignition it will comr back the wires connect into the loom so if its a cluster wire it coil be a break anywhere from the cluster to the fuse box
Link to comment
i hope your right.
started coming on a lot know ,the engine light is on all the time and keeps coming up with engine mailfunction and limp mode .
will chck the speedo and go from their
Link to comment
Take photo with phone to remember where everything goes unplug everything on the fuse box and take it out of the car. Spray everything the electrical cleaner ( not WD40) I slightly bent every connector as per RAC man, to much and the connectors won't go back on.
Link to comment
im really at a lose .ive looked at the speedo all seems fine.ive got passenger seat out and when i play with the wires it goes of but not always .cant see anything amiss.
will try fuse box tomorrow bit dark now.
any help would be good .
Link to comment
high speed can errors random engine management lights false codes usually I cluster or cluster wiring the fuse box only relates to mk1 where the pollen filter was in the footwell mk2 doesn't have that issue you say looked at the speedo not sure if you did as suggested pull it out completely with multiplug attatched and engine running clear the codes restart engine then try the wiring sometimes even banging on the dash will throw the light on had a similar issue and got rid of the thing
Link to comment
i did take the speedo out and pulled on the wires and plug but didnt make it throw up errors.it seems to do it when i play with the wireing in passenger foot well ,not sure if it coincidence or not .not sure what else to look for
Link to comment
right had enough now.
thought id found the problem ,the fuse box looks like it had some water on it .cleaned it up cleaned all the pins and the fault still happens.
it seems every time i play with the wires in passenger footwell the alarm goes of .just cant see any thing just left it and the alarm goes of every time i turn the key now.
could it be a simple broken wire causing it ?
any help would be appreciated .
Link to comment
it could be a few broken wires by the sound of it the problem is which ones and where youve got more patience than me i just traded the bloomin thing in
Link to comment
my problem is i cant afford to trade it in
found the fuse box was like this
could this have cuased damage some where ? dont know how its got like that ..ive cleaned it up and its better .
will be back on it tomorrow
Link to comment
13 minutes ago, artscot79 said:
that can certainly cause the issues you're having cleaning it up may work otherwise its a new fuse box
the enging warning light comes on when the car is just standing and not running.
when i checked for codes it said theft detected imobiliser switched on or something like that .
Link to comment
you have got problems then try cleaning it up hopefully that works if not the whole fuse box will need replaced in not sure if its a straight swap or if any coding I needed
Link to comment
ive cleaned it up.even desoldered the on board relays,there was gung under the relays so cleaned the board and the relays up and resoldered them but still the same.
not sure if its just a fluke that when i move the wires that the alarm goes off or its the wire.just cant see any breaks .been on it all day.
what part on the fusebox would be the actual one to look for ?
Link to comment
The higher lettering usually denotes an updated version which would handle functions on higher spec cars.
Shouldn't be a problem as long as you go higher.
Tbh though, seeing as you're having such problems now, fitting a higher spec board may not be beneficial to you.
I found this one for you-
http://pages.ebay.com/link/?nav=item.view&id=141952844916&alt=web
Not cheap but looks clean.
I'd as them for a picture of the underside though to be sure though.
Sent from my SM-G930F
Link to comment
Tbh though, seeing as you're having such problems now, fotting a higher spec board may not be beneficial to you.
i no like £128
ive seen one with the same number but JG instead of DE do you think it would be ok ? the guy recons the de is crucial .it says push button start .
do they really have to be coded to the car ?
Link to comment
If it's the same model number and from alike for like car then it is plug and play. If it is a different model it may need some options setting up with diagnostics.
Link to comment
ive got elm so not a problem .would a tdci one with push button start work on my petrol car ?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
