Why does air recirc turn off by default?
Jason87
 Share
When I use the fans and then turn them off, the recirc button stays lit meaning the vents are closed, why is this? I though recirc should be on as default to get fresh air into car?
Link to comment
its to stop the build up of co2 since it recirculates the air in the cabin with no fresh air all the co2 you breath out is also recirculated its set to auto switch off after 5 mins to prevent you killing youreself should you be in a cold climate stuck with the engine running that's how many people die you always want recirc off prevents condensation misting of windows its fine to put on if there's a bad odour outside for a few minutes or when you're car is hot inside from the sun you put recirc on window down aircon on cold and it will cool the inside quicker
Link to comment
What I mean is it seems it turns recirc on by default as in vents closed and no outside air coming in, but I thjnk this is just when the dial is set to cold
Link to comment
Are you sure it's recirc not the demist?
Manual aircin on Fords automatically activates demist if the vents are set to windscreen.
Turning the vent dial a couple of notches off either side of windscreen stops this.
Sent from my SM-G930F
Link to comment
No it's the button next to the ac button which both light up when the dial is on cold and fan is on. Which I thought is due to cooling reasons but when I turn the fan off the ac button light goes out but the Recirc button light stays on?
Link to comment
i can never remember the focus automatically switching recirc on at any point it was always free air unless I pressed it to come on or can this be set using the software?Some vehicles have a max air conditioning button that automatically requires the recirculated to be used. While the air can cool down faster and stay cooler,
Link to comment
9 hours ago, Dee_82 said:
My 2.5 doesn't do it.
makes sense though
Neither does my mk2 facelift!
Link to comment
I think the logic behind it is that, if your shutting off the blowers its for a reason, either to keep the air outside out or keep in the air inside in.  If you shut the blowers off without locking out the outside air, wouldn't the air just get forced in as you drive along? turning on recirc  blocks that outside access, at least that what i would have thought... never seen it before tho, ill try it on my partners festa when i get the chance. :)
Link to comment
Tried this earlier, doesn't seem to do it in mine either.  The AC switches off when blowers are switched to 0, vents on face and and temp on cold but the recirc doesn't come on.
Link to comment
Mine doesn't do it either.
Is it an option in the ECU (like the auto-aircon)? I wonder if they changed it at some point, or for a certain batch of ECU's (/BCM's whichever module sorts the climate out)
Link to comment
like I said recirc is dangerous if left on fir too long in my old manual it states if the inside of the cabin is hot to cool put temp control to max cold open a window switch aircon on aim vents to desired position fan on max once the air has cooled set temp to desired temp switch recirc off and use fresh air ....the recirc will automatically switch off after a period of 5 minutes this is a safety feature the recirc should not be used for any longer without a window being open.....
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
