Collins Posted May 4, 2016 Share Posted May 4, 2016 So my 2002 2.0 focus won't turn its fans on, with or without ac on and the needle nudging the red. I've checked the fuses and the relays and they seem to be fine. I've applied power directly to the resistor and the fans work. I'm stumped at what to check next. Quote Link to comment Share on other sites More sharing options...
Russ Posted May 4, 2016 Share Posted May 4, 2016 47 minutes ago, Collins said: So my 2002 2.0 focus won't turn its fans on, with or without ac on and the needle nudging the red. I've checked the fuses and the relays and they seem to be fine. I've applied power directly to the resistor and the fans work. I'm stumped at what to check next. Faulty temperature sensor showing overheating when in fact the temperature is 'normal'? Quote Link to comment Share on other sites More sharing options...
Collins Posted May 4, 2016 Author Share Posted May 4, 2016 Cheers Russ. I think it must have been a dirty connection some where as both fans now seems to be working fine. Here's hoping it's nothing more! Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 4, 2016 Share Posted May 4, 2016 first sign of the sensor going is intermittent working itll work fine then go into the red etc Quote Link to comment Share on other sites More sharing options...
