pce13 Posted May 4, 2016 Share Posted May 4, 2016 Hi. When I pull off turning right with half to full lock I get a chattering sound which indicates worn outer cv joint, I can undo the lower arm ball joint nut and lower it out the way, undo the bolt going into the cv joint but for love nor money can I get the cv joint to slide out of the hub! I tried a hub puller to push the joint out but it's seized solid! Any tips or ideas how to get the cv joint out of the hub? Thanks in advance Paul Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 4, 2016 Share Posted May 4, 2016 penetrating fluid and brute force usually if its siezed Quote Link to comment Share on other sites More sharing options...
