Bobr Posted May 5, 2016 Share Posted May 5, 2016 On Tuesday last I picked up a Fiesta ecoboost 100 with 20,000 on the clock. Since then I've done about 200 miles, mostly in town, and the stop start system hasn't worked once. Any advice please? Quote Link to comment Share on other sites More sharing options...
Leebrindley Posted May 5, 2016 Share Posted May 5, 2016 Are you sure it has it fitted my focus has a bottem on the dash with an A symble on it that's what I use to turn it off in heavy start stop traffic Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 5, 2016 Share Posted May 5, 2016 Stop start is a very fussy system. The battery has to be above a certain charge level, it can't be too hot, too cold, there can't be too much electrical load, there can't be too much A/C load. etc. It might need a long run to charge the battery a bit if you've been doing mostly town driving. If the car has been sat around for a bit before you bought it, that will have drained the battery too. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 5, 2016 Author Share Posted May 5, 2016 4 minutes ago, alexp999 said: Stop start is a very fussy system. The battery has to be above a certain charge level, it can't be too hot, too cold, there can't be too much electrical load, there can't be too much A/C load. etc. It might need a long run to charge the battery a bit if you've been doing mostly town driving. If the car has been sat around for a bit before you bought it, that will have drained the battery too. Thanks Alex it has been stood for some time. I'm going to Scarborough on Saturday and back via Wakefield so that should give the battery a good charge. If it doesn't work then I'll refer it back to Ford as it has a years warranty. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 8, 2016 Author Share Posted May 8, 2016 I did 276 miles yesterday. As I left Nottingham the stop start system worked twice. It hasn't worked since. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 8, 2016 Share Posted May 8, 2016 take it back to your ford dealer, bet they say battery needs charging regardless of your journey. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 8, 2016 Author Share Posted May 8, 2016 Yes Ian. It's going back tomorrow. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 8, 2016 Share Posted May 8, 2016 let us know what the outcome was when its fixed. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 8, 2016 Author Share Posted May 8, 2016 I will IF it's fixed. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 8, 2016 Share Posted May 8, 2016 they should be able to, you can do it if you have a battery charger, i found if you charge battery up first , then reset battery monitoring , stop start works fine after. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 10, 2016 Author Share Posted May 10, 2016 Funnily enough, chucking it down with rain this morning and the stop start has worked every time. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 10, 2016 Share Posted May 10, 2016 Did you take it back to garage for them to look at? Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 10, 2016 Author Share Posted May 10, 2016 No I didn't as I couldn't see the point as it is now working perfectly every time. It's colder today and i wonder if the hot temperatures we've had over the last few days have had something to do with it. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 10, 2016 Share Posted May 10, 2016 If it's too hot it won't stop to keep the coolant going round the turbo. Unless you have a newer 1.0 that's got the pump or have retro fitted it, then it will use that instead so might shut off more often. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 10, 2016 Author Share Posted May 10, 2016 15 minutes ago, alexp999 said: If it's too hot it won't stop to keep the coolant going round the turbo. Unless you have a newer 1.0 that's got the pump or have retro fitted it, then it will use that instead so might shut off more often. Thanks Alex. I know very little about this engine never having had one before so how would I know if it has the pump? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 10, 2016 Share Posted May 10, 2016 You can see it attached to the radiator fan housing. Difficult to know what you are looking for, I'll see if I can find a picture, if not I'll try and remember to take one on of it on my Dad's Fiesta at the weekend. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 10, 2016 Share Posted May 10, 2016 you cant exactly see it, behind a bracket, the key toknowing is to look at turbo and see the 2 coolant pipes on the right of turbo. and follow the lower pipe, if you have pump it will go dow to near bottom of radiator, if it goes down a short way and then turns back to engine , then you havent. Quote Link to comment Share on other sites More sharing options...
