J Posted May 7, 2016 Share Posted May 7, 2016 Hi All, Not sure if anyone can help I have a 63 plate titanium X petrol, had two new front tyres fitted yesterday. Noticed that the steering wheel wasn't sitting straight but wheels were so took it to a specialist tracking place and they did some tests and realigned however, I still have the same problem. The steering wheel is sitting more over towards the right. Also I have an issue with the fan cutting in, the other evening I drove 7 miles at about 21:30 so it was fairly cool yet my fan kicked in for a good 10 mins after the engine went off. This is happening frequently but ford keep telling me it's normal?????!!! any help, advice or suggestions would be great Quote Link to comment Share on other sites More sharing options...
Russ Posted May 7, 2016 Share Posted May 7, 2016 The fan kicking in is normal as the ECU monitors the engine temperature for a while after you switch the ignition off and kicks in if needed. When you had the tracking done the chances are they have only done one side, they should have tracked (adjusted) both sides and ensured the threads showing on the driveshafts were even on both sides. (Basically you will now have more threads showing on one driveshaft than the other) because of that the wheel will not sit correctly. They should also have made sure the stearing wheel was correctly positioned and locked before they did the tracking. 2 Quote Link to comment Share on other sites More sharing options...
J Posted May 8, 2016 Author Share Posted May 8, 2016 Hi Russ thank you for your response. They claimed they did do both sides they put some sensors on and put the readings on the screen there was one red reading and after adjustment all readings were green. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 8, 2016 Share Posted May 8, 2016 How much is the steering wheel off centre? If it is just a small bit it can be caused by the camber/curved surface of the road. The camber of the road makes it necessary to counter steer a bit which makes the steering wheel stand a small bit off centre while driving in a straight line. This can be minimized by putting the steering wheel a small bit off centre (in te opposite position) before the wheels are alligned. Quote Link to comment Share on other sites More sharing options...
J Posted May 8, 2016 Author Share Posted May 8, 2016 Hi JW1982 thank you for your reply, when the wheels are straight the steering wheel is sitting about 6 inches out Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 8, 2016 Share Posted May 8, 2016 That is way too much. Personally i would go back to the specialist who alligned the car If the wheels are alligned to the correct specifications while the steering wheel is locked in the center position the steering wheel should not be that much off center. They must have done something wrong or there is a serious problem with the steering system. If the problem arised after fitting the new tyres I would also check the tyres, tyre inflation and if the wheel nuts are tightened correctly. Quote Link to comment Share on other sites More sharing options...
Enduser Posted May 8, 2016 Share Posted May 8, 2016 I have had my tracking checked in the past, they used a Laser device but before they did any adjustments they clamped the steering wheel centrally. They fitted things to ALL four wheels, maybe they, someone forgot to clamp the steering wheel first, or they were not properly trained, apparently it is possible to adjust all four wheels !. I would defiantly take it back. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 8, 2016 Share Posted May 8, 2016 53 minutes ago, JW1982 said: If the problem arised after fitting the new tyres I would also check the tyres, tyre inflation and if the wheel nuts are tightened correctly. This! Unless you've hit a pot hole or kerb, or replaced a suspension/steering component, there is no reason for the wheel to 'just' end up 6" out of line. If it was only after the tracking was done then take it back and have them do it properly...chances are they won't be able to though, most places that offer tracking can't seem to do it in my experience! Quote Link to comment Share on other sites More sharing options...
J Posted May 8, 2016 Author Share Posted May 8, 2016 Thank you all, I am taking it back this morning so will see what they say Quote Link to comment Share on other sites More sharing options...
J Posted May 8, 2016 Author Share Posted May 8, 2016 So took car back and this is now my reading and how the steering wheel is sitting when tyres are straight Quote Link to comment Share on other sites More sharing options...
Russ Posted May 8, 2016 Share Posted May 8, 2016 Look under the car at your track rod ends, measure the visible threads on both driveshafts and check they are equal lengths. Had a fiesta mk3 done at quick fit once, cause they didn't do both sides equally the stearing wheel was 30 degree off, they wanted to strip the stearing column down!!!!! No thanks, went to ford, had it done right & never gone to quick fit since! Quote Link to comment Share on other sites More sharing options...
james1089 Posted May 9, 2016 Share Posted May 9, 2016 top strut mount could be seized but doubtful. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 9, 2016 Share Posted May 9, 2016 Annoyingly the Ford steering wheels don't have much movement, they use a 6pt nut rather than a spline so it's not even like you pull the wheel off and turn it a bit. Russ is right, although the computer shows the angles are all fine, they've moved one TRE more than the other, should've locked the wheel central first. Quote Link to comment Share on other sites More sharing options...
Bobr Posted May 9, 2016 Share Posted May 9, 2016 16 hours ago, Russ said: Look under the car at your track rod ends, measure the visible threads on both driveshafts and check they are equal lengths. Had a fiesta mk3 done at quick fit once, cause they didn't do both sides equally the stearing wheel was 30 degree off, they wanted to strip the stearing column down!!!!! No thanks, went to ford, had it done right & never gone to quick fit since! 16 hours ago, Russ said: Look under the car at your track rod ends, measure the visible threads on both driveshafts and check they are equal lengths. Had a fiesta mk3 done at quick fit once, cause they didn't do both sides equally the stearing wheel was 30 degree off, they wanted to strip the stearing column down!!!!! No thanks, went to ford, had it done right & never gone to quick fit since! I went to Quickfit once. 1 Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 9, 2016 Share Posted May 9, 2016 Both front wheels need to be tracked to the right to straighten the steering wheel up. Quote Link to comment Share on other sites More sharing options...
J Posted May 12, 2016 Author Share Posted May 12, 2016 Thank you all for your responses I'm on my way to ford. 1 Quote Link to comment Share on other sites More sharing options...
