sonic113 Posted May 8, 2016 Share Posted May 8, 2016 Something that has been bugging me for a long time is at high speeds 50 to 70 mph i get a wind noise on my two front doors as if the windows are down a little. Passengers have ask is the windows closed too many times now so i think ots time to investigate this lol! Does anyone else who has teamheker deflector get this? I thnk i have them installed correctly , i hope so they have been like this for the past 3 years lol! Just 2 little clips that pop up inside the window runner one end hits against the plastic deflector and the other against the window rubber. I have tried adding a strip of that draught proofing stuff to the edge if the deflector in driveres door to try it out and see if it helps so i will know more by tomorrow. Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted May 8, 2016 Share Posted May 8, 2016 I don't know about you, but I didn't use the metal clips. Go buy some "No More Nails" on a roll, it's red and thick. Stick that along the front and back edge and put it back in, and then lose your window for 48hours. I've had my deflectors on for 6 months on front and back and still no wind noise. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 8, 2016 Share Posted May 8, 2016 I left the clips out when I fitted the Heko's to my Mk 2.5 when I had it. Still had the increased wind noise but I got used to it. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 9, 2016 Share Posted May 9, 2016 they all do it if you drive in the rain watch how the rain comes off the deflector as you drive the wind catches the edge forcing the water up and away from the window as a result the wind will whistle against it the focus is poor for wind noise anyway so it doesn't matter if it has them or not Quote Link to comment Share on other sites More sharing options...
sonic113 Posted May 12, 2016 Author Share Posted May 12, 2016 On 08/05/2016 at 7:16 PM, sean.kerwin said: I don't know about you, but I didn't use the metal clips. Go buy some "No More Nails" on a roll, it's red and thick. Stick that along the front and back edge and put it back in, and then lose your window for 48hours. I've had my deflectors on for 6 months on front and back and still no wind noise. Sent from my iPhone using Tapatalk Sean have you got any pictures of them installed? was wondering that when the "NO MORE NAILS" hardens and you ever break a deflector or need to take one out would that stuff not wreck the rubber around the window seal or even crack through time with the heat and vibration of the car moving ect? cheers Quote Link to comment Share on other sites More sharing options...
