How to remove bush scratches
Jason87
 Share
After my recent posts about paintwork I'm annoyed to have driven past a bush and got several long light scratches along the side of the car, will these be easy to remove? I'm annoyed a bush can scratch paintwork as I didn't thjnk it would be strong enough, would meguairs scratch X do the job?
Link to comment
Unfortunate that Jason if it's not one thing then it's another and you sure are having bad luck with your cars paintwork.
Yes meguires scratch x will do the job and then you'll have to use a polish after it coz scratch x is a roughish stuff and leaves millions of minute scratches which needs a polish to bring back to a sheen. Maybe even a wax application too.
Link to comment
Is this a permanent fix though? Or does that just mean each time j wash and wax the car it will look clean?
Link to comment
is the scratch deep enough to feel when you run your thumb nail across the paintwork ?
if so it may require a touch up with a paint chip kit as its gone through the clear coat
if not and is just surface grazing then Meguiars scratch X or the less abrasive ultimate compound will get the worst out with alot of hand polishing using a foam applicator
neither will harm your paintwork in any way
i use the ultimate compound for my cars annual polish , great product for removing swirls and UV oxidisation
Link to comment
No I can't feel the scratches, which is why I'm surprised a bush managed to scratch, so scratch X takes a tiny layer of laquer off but doesn't do any harm?
Link to comment
As my scratches are almaot the cars length, guess I'll have to do circular motions all the way along and hope it doesn't look different to the rest of the paintwork lol
Link to comment
I'm worried about taking too much layer off, the scratches are really light so I'm hoping I'll be able to notice the scratches going after a few rubs
Link to comment
Do a few rubs and see. If more rubs are needed then do so. Experiment on a section till your happy with the result then do the rest of the scratched area.
Link to comment
Does wax hide scratches? As I've only had my car 2 weeks and it's been waxed and cleaned since last few days due to rain, now I've noticed a few scratches which I didn't before, so I'm guessing the rain has washed the wax off so the scratches are more obvious?
Link to comment
Me personally if a finger nail can't be stopped by the scratch, then it's only surface brushing!
I'd use 2000 grade Wet & dry paper on the scratches ONLY - Using warm water & plenty of washing up liquid so the paper glides over the surface, then followed by T-Cutting and final polish. I've done dozens of cars in the past and every one was a winner.
2000 grade paper can't be found in most car shops! Wet & dry paper can go up to 3000 grade, two manufacturers which produce this very high quality paper: Klingspor & Matador.
NEVER use 1200 grade paper as this WILL strip back the paint straight away.
Link to comment
Standard waxes will normally bring out scratches due to the white polymers in the product. There are coloured waxes available which will hide scratches.
Link to comment
Well the far was cleaned by ford and then I gave it a clean, only now it's been raining a bit and getting dirty I've noticed some more scratches which weren't there before, guess ford used something on it
Link to comment
At a guess that Ford dealership used a 'Quick Shine Detail wax' ? Its a clear spray on product, rub into the paint and then buff up to a lustre, fine scratches just disappear but its a quick fix, not long lasting though.
Link to comment
Wax or quick detailer does hide scratches, polish even better...  Trust me haha! :wink: I drive loads of single track roads and bush scratches are unavoidable, I haven't found anything that I can use by hand to remove them though, even scratch x and ultimate compound haven't done anything, so have gone back to just hiding them until I can afford to have it mopped lol.
Link to comment
You're saying scratch X won't even remove light bush scratches?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
