jimbomc96 Posted May 11, 2016 Share Posted May 11, 2016 Hi all, new here! So I have my 16 focus zetec s on coilovers, fairly low, hit a hard bump on m62 and a minute later speedo stops working, abs and stability control fault light came on, hill start assist not available, basically anything related to the abs sensors. Every time I apply gas or let off there is a small knock from the front left as if something has developed some backlash. Any ideas where I should be looking for the problem? Already cleaned all the abs sensor connections. Any advice appreciated, thanks. James Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 11, 2016 Share Posted May 11, 2016 Have you checked for play to make sure nothing is mechanically damaged or out of place? Might be that the shock has caused the sensor to fail if it has lit up the dash. An error code reader should tell you more. If the sensor has failed, Ford will probably not honour the warranty with it being on coilovers though. Quote Link to comment Share on other sites More sharing options...
jimbomc96 Posted May 11, 2016 Author Share Posted May 11, 2016 I have, everything accessible is okay , I'll run a code reader later on see what that can tell me. If it comes down to it I'll have to remove coilies and play dumb with ford. Thanks for the help I'll keep you posted. Quote Link to comment Share on other sites More sharing options...
