SSmith44 Posted May 14, 2016 Share Posted May 14, 2016 The fuse was pulled out for my 03 Ford KA radio and now it's asking me for the code. I followed the instructions by pressing 1 and 6 together to get a serial number which came up as MGP DJS then another number flashed up as 4-04 then more numbers said 04-03-00 I can't believe it has to be so complicated to use the radio. I looked online for the same code and the numbers given to other people didn't work, and I read if you try too many times that the radio completely locks so you can never use it. Will I ever be able to use the radio again? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 14, 2016 Share Posted May 14, 2016 None of the numbers you listed is the radio serial number. You should be looking for a number starting with M or V. Once you have that then search eBay for a code service or go to a Ford dealer with your V5C documents. If you can't pull up the serial via the screen then it is on a sticker on the radio casing, get the radio pulled out and you should find it. Sent from my SM-G930F 2 Quote Link to comment Share on other sites More sharing options...
Russ Posted May 14, 2016 Share Posted May 14, 2016 5 hours ago, SSmith44 said: The fuse was pulled out for my 03 Ford KA radio and now it's asking me for the code. I followed the instructions by pressing 1 and 6 together to get a serial number which came up as MGP DJS then another number flashed up as 4-04 then more numbers said 04-03-00 I can't believe it has to be so complicated to use the radio. I looked online for the same code and the numbers given to other people didn't work, and I read if you try too many times that the radio completely locks so you can never use it. Will I ever be able to use the radio again? As Stoney said, look for a number starting M or V then google ford serial number generator (loads of websites) or go to eBay or Ford. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 14, 2016 Share Posted May 14, 2016 you wont find it by the 1&6 , radio out to see m number Quote Link to comment Share on other sites More sharing options...
Rochelleac Posted May 14, 2016 Share Posted May 14, 2016 Could you possibly tell me my radio code for my KA? I had a new battery fitted and don't have any paper work for the radio. I have the serial number off the side of the radio itself. It's M008487. Thank you! Silly me. Will look on eBay Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 14, 2016 Share Posted May 14, 2016 5 minutes ago, Rochelleac said: Could you possibly tell me my radio code for my KA? I had a new battery fitted and don't have any paper work for the radio. I have the serial number off the side of the radio itself. It's M008487. Thank you! Sorry, this club does not provide codes. M codes are easily obtained using a code generator freely available on the internet. http://www.freefordradiocode.co.uk/radio/content/ford-m-serial-radio-code-generator.php 1 Quote Link to comment Share on other sites More sharing options...
SSmith44 Posted May 14, 2016 Author Share Posted May 14, 2016 I can't believe it's so much hassle. I need to buy a tool to pull the radio out to see that code. Ford place was closed in the afternoon, so I bought a portable radio to listen to in the car. Quote Link to comment Share on other sites More sharing options...
Omendata Posted May 15, 2016 Share Posted May 15, 2016 That's modern car security for you - you could make your own tool with a thin coat hanger or some 13mm copper mains wire and a file to get round the "security" - ahem. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 15, 2016 Share Posted May 15, 2016 Halfords do the radio keys, or 4 rivits do the job also . 1 Quote Link to comment Share on other sites More sharing options...
