rupert88 Posted May 16, 2016 Share Posted May 16, 2016 Hi guys, I have recently started a bit of a project on my 2009 Ford Focus Titanium to retrofit mirrors with puddle-lamps and power fold capability. I removed the old mirrors and attached new (aftermarket) mirrors with puddle lamps and power fold. I purchased a two-way button from Ford which replaces the standard interior scan button by the door handle. (I dont have the power fold switch integrated on the drivers door arm rest module). After a search on Google ive figured out where the extra wire needs to go on the drivers door control unit (the passenger mirror connector is fully populated) to power the drivers side mirror fold motor. Current Progress I've managed to turn on the puddle lamps with ELMConfig. Currently when i lock the car the mirrors move in a bit (and it seems using the mirror adjustment switch i can move them out again using the left arrow ?). The puddle lamps seem to be working properly. Questions Q1) How can i wire up the two way button pictured above? Q2) What settings do i need to flick in ELMConfig so the car knows it has powerfold/puddle lamps (I have a modified ELM327 clone with an MS CAN switch)? Q3) Is there any mirror learning procedure required so the car knows how much to fold the mirrors in or out (like global opening/closing for the windows)? Any help would be greatly appreciated! Thanks. Quote Link to comment Share on other sites More sharing options...
blue crush Posted May 18, 2016 Share Posted May 18, 2016 Ive never seen that switch before.. Have you got the finis code for it and links to parts to have powerfold mirrors as i am interested in this also. Hopefully someone must know how to get it working via ELM config too. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 3, 2016 Share Posted June 3, 2016 On 16/05/2016 at 3:03 PM, rupert88 said: Hi guys, I have recently started a bit of a project on my 2009 Ford Focus Titanium to retrofit mirrors with puddle-lamps and power fold capability. I removed the old mirrors and attached new (aftermarket) mirrors with puddle lamps and power fold. I purchased a two-way button from Ford which replaces the standard interior scan button by the door handle. (I dont have the power fold switch integrated on the drivers door arm rest module). After a search on Google ive figured out where the extra wire needs to go on the drivers door control unit (the passenger mirror connector is fully populated) to power the drivers side mirror fold motor. Current Progress I've managed to turn on the puddle lamps with ELMConfig. Currently when i lock the car the mirrors move in a bit (and it seems using the mirror adjustment switch i can move them out again using the left arrow ?). The puddle lamps seem to be working properly. Questions Q1) How can i wire up the two way button pictured above? Q2) What settings do i need to flick in ELMConfig so the car knows it has powerfold/puddle lamps (I have a modified ELM327 clone with an MS CAN switch)? Q3) Is there any mirror learning procedure required so the car knows how much to fold the mirrors in or out (like global opening/closing for the windows)? Any help would be greatly appreciated! Thanks. i done this about a year ago.i found one wire goes from switch to door module and door module to mirrors .you might find my post some where with wire diagrams . also if the elm is not on the right setting just flick the switch to the right setting .once wired up you will be able to just fold the mirrors with the switch . the best thing is when you have them fold when you lock the car that switch i bought and found i had to take the innerds out and put them in to the one on the door as the plug is different Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted June 3, 2016 Share Posted June 3, 2016 I guide on this would be welcome for quite a few mk2.5 owners... I was going to get an aftermarket job from there guys http://www.thespeedline.com/exterior-22/ but if I can keep this OEM id be very interested Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted June 3, 2016 Share Posted June 3, 2016 2 minutes ago, Dee_82 said: I guide on this would be welcome for quite a few mk2.5 owners... I was going to get an aftermarket job from there guys http://www.thespeedline.com/exterior-22/ but if I can keep this OEM id be very interested i did put wire diagrams some where last year .id have to take my door cards off Quote Link to comment Share on other sites More sharing options...
