lucas1787 Posted October 30, 2009 Share Posted October 30, 2009 Hi,I have a Treg 1.6 zetc Focus and I need to fit an alternator to it.I have been told if I disconnect the battery the ECU will have to reprogram itself???. Iam not sure if this is correct. Could some advise please if this is correct and should I not do this or is there anything else I should worry about?.Thanks Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 30, 2009 Share Posted October 30, 2009 the ecu will reprogramme itself after a drive once the jobs done take it for a drive for ten to fifteen miles and it relearns. only thing to watch is you have the radio code thats about it . Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted October 30, 2009 Author Share Posted October 30, 2009 the ecu will reprogramme itself after a drive once the jobs done take it for a drive for ten to fifteen miles and it relearns. only thing to watch is you have the radio code thats about it . Thanks for that,one other thing the tension to remove the belt,do i just put on a spanner on and then pull it towards me to release it? Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 30, 2009 Share Posted October 30, 2009 Thanks for that,one other thing the tension to remove the belt,do i just put on a spanner on and then pull it towards me to release it? losen the alternator then push fowards to lift off ;) Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted October 30, 2009 Author Share Posted October 30, 2009 losen the alternator then push fowards to lift off ;) many thanks for all the info,I will give it a go. Quote Link to comment Share on other sites More sharing options...
