Mattypompy Posted May 30, 2016 Share Posted May 30, 2016 Cannot enter remote programming mode Hey Peeps, My issue is i have a 3 button remote for my mk1 focus tdci 2002 and i cannot get the vehicle to enter programming mode to program the remote lock / unlock function on the key, i get no "gong" or any noise, and i cannot figure out what the issue is, here is what i have tried so far : Position 1 - 2 4 times, no response Position 0 - 2 4 times, no response Position 2-1 4 times, no response Plugged out central locking control unit connections, left for 40 minutes reconnected, and tried the above again. Disconnect battery for 20 minutes and tried again no result. Something, somewhere else must be the issue, my last resort is bothering you guys, but as you can see i've tried a fair amount of things. Basically it was working fine then I changed the battery for no particular reason now it's dead. The CL works manually from inside but i only have a key that manually opens tailgate not doors, so thats how i'm getting in atm! Dont wanna go to Fords!! Thanks!😀 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted May 30, 2016 Share Posted May 30, 2016 you need to be quick easiest way Is o to pos 2 4 times in six seconds you will hear the noise press any button on the fob and spare fobs then you'll hear the noise again now switch off its getting it within the 4 seconds if it doesn't work pos o-1 Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 30, 2016 Author Share Posted May 30, 2016 I'll give it another go buddy. Cheers. Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 30, 2016 Author Share Posted May 30, 2016 No joy. Dunno what's wrong with it as everything was fine before I changed the fob battery. Don't see how it could be the CL module as that is locking manually. The programming mode just won't operate, don't really want to try Ford or an auto electrician but may have to. Maybe I'm just doing the programming wrong but I don't see how. Any other suggestions would be fan. Thanks.😀😀 Quote Link to comment Share on other sites More sharing options...
williamweb Posted May 30, 2016 Share Posted May 30, 2016 Try a different fob battery. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 30, 2016 Author Share Posted May 30, 2016 I've tried two batteries both tested with a DVM. The thing is the car won't go into programming mode as there is no chime and no continuous led unless that's not always the case, then I guess it could be the fob? Thanks so much.. Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 31, 2016 Author Share Posted May 31, 2016 I've tried two batteries both tested with a DVM. The thing is the car won't go into programming mode as there is no chime and no continuous led unless that's not always the case, then I guess it could be the fob? Thanks so much.. If I get a solution I will post up here for others. Quote Link to comment Share on other sites More sharing options...
simcor Posted May 31, 2016 Share Posted May 31, 2016 Mine does not chime anymore when I do the key sequence but it chimes when I press the buttons on my remote and still reprograms them but I know I have a dicky gem after it got wet. I need to replace my gem at some point. Does yours chime when you press the remote buttons or not after doing the key sequence? Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 31, 2016 Author Share Posted May 31, 2016 I get no chime at all even when pressing fob. I suppose I could get a new fob and try that just in case I damaged it while changing battery? About £8 on eBay. I was just about to call Ford's or an auto electrician. Might be worth a try? I have tried everything. Fuse checks, key sequence, fob battery test, cl unit unplug and multiplug in glovebox. I'm defeated if fob doesn't work. Maybe I need an ecu update or some system reset. Cheers anyway. Arghh!!!! Quote Link to comment Share on other sites More sharing options...
Tandem Posted May 31, 2016 Share Posted May 31, 2016 Hi Just got my focus and had to re-programme my key. Combination of flat car battery and flat remote battery had broken the link between fob and car. Tried several times, but in the end it was steady but quick turning that cured the problem. If you sit with everything electrical switched off you can hear the noise, but it sound like a quiet service bell you hear in old hotels. Once you get that noise, the red light above the clock comes on and you can then sort out you key fob. It takes patience, but should happen eventually. If not go indoors, have a pint and try again an hour later Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted May 31, 2016 Author Share Posted May 31, 2016 Last bit of advice sounds great mate!! Will try your suggestion. Cheers😁😁😁😁😁 Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted June 10, 2016 Author Share Posted June 10, 2016 OK so the mechanic looked at this today and couldn't fix it. He reckoned the ignition switch/barrel is worn and therefore will not initiate 'programming mode' via the key movements. It is a bit worn. He reckons replace then reprogram key. Any advice to an easier solution??!!! Cheers Quote Link to comment Share on other sites More sharing options...
Mattypompy Posted June 15, 2016 Author Share Posted June 15, 2016 Changed ignition switch and barrel. Still cannot get into 'programming mode'. Any ideas guys, I'm getting to the point of quitting! Not worth getting Ford or an autoelectrician to look at it. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 16, 2016 Share Posted June 16, 2016 if nothings working then all I can suggest I check all the fuses maybe ones blown I'm sure there's one for cl in either the footwell or engine bay also make sure all the connectors on the fusebox are fully in if thats all okay sounds like the cl module may have gone Quote Link to comment Share on other sites More sharing options...
