Max Posted June 8, 2008 Share Posted June 8, 2008 Hi, a problem has just developed with my Fiesta. No matter what position I put the fan direction control knob in it stays stuck on demist. Clearly it is a problem with the knob, I was wondering if this is an easy problem to fix or will I have to take it in for repair? Thanks Quote Link to comment Share on other sites More sharing options...
Steve Posted June 8, 2008 Share Posted June 8, 2008 it may be jammed with a bit of debris. is it mechanical or electronic? Quote Link to comment Share on other sites More sharing options...
Max Posted June 8, 2008 Author Share Posted June 8, 2008 it may be jammed with a bit of debris.is it mechanical or electronic? It's definitely not an eletrical problem, it has to be the knob itself. I can keep turning the direction control knob around and around, so clearly the knob isn't connected properly. Should I just unhuck the center console and to see if I can reconnect it. Quote Link to comment Share on other sites More sharing options...
Steve Posted June 9, 2008 Share Posted June 9, 2008 the knob sounds broken.. can you pull the knob off? (said the actress to the bishop LOL) bit of glue may do the trick Quote Link to comment Share on other sites More sharing options...
Max Posted June 11, 2008 Author Share Posted June 11, 2008 the knob sounds broken.. can you pull the knob off? (said the actress to the bishop LOL)bit of glue may do the trick Right fixed it, the previous owner had put their own CD head unit in and whilst doing it they must have detached a metal cable that runs from the control nob to the right back of the centre console. All I had to do was plug it back in, and now I have direction control :D Hope this helps anyone who has similar problems Quote Link to comment Share on other sites More sharing options...
