Throttle pedal stuck open while driving.
rijost
 Share
I am a newish member and this first post.
Had my current Focus ( Reg September 2010) Titanium automatic  since beginning of May
While driving my accelerator jammed open while driving. I managed to overcome by hitting brakes hard. Is this a know issue?
Link to comment
That is a rather serious problem that needs urgent attention. You did not say if diesel or petrol, diesel is possibly worse.
First check for mechanical problems: Car mats, free movement of pedal.
Electrically, this should not happen, and I have not heard of major throttle sensor problems. It will be a dual redundant sensor with continuous monitoring, and is a safety critical part. Sometimes small errors that just affect the idle may get through, but not enough to make the car hard to stop. I take it no warning lights appeared?
I would advise getting this fixed before using the car on the road again! If under warranty, take it back, or ideally, get them to collect it.
On a lighter note, I had a Hillman Imp, where the throttle link could fall off the carb, and it then was biased to open fully! Did this several times. But on a Hillman Imp with its 850cc engine and 0-60 time probably measured in minutes (or hours uphill), it was not too serous! Just one more of its little(?) foibles.
A modern 1.6l Focus is a different matter!
Peter.
Link to comment
Peter,
Thanks for response. The engine is petrol and the car is going in for a check tomorrow. After the incident I continue to drive ( had no choice) without incident, but wary of issue. I have heard this problem occurring, but rarely, on London taxis.
I remember the Imp well, but never owned one.
Rijost
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
