beethoven Posted July 11, 2016 Share Posted July 11, 2016 I want to diassemble the foglights to install LED's Quote Link to comment Share on other sites More sharing options...
pragmatix Posted July 11, 2016 Share Posted July 11, 2016 I suspect it's like the mk4, if you look under the fog light bumper area on the under tray you will find 2 large holes that allow entry to the mounting screws for the fog lights 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted July 12, 2016 Share Posted July 12, 2016 I was under the impression it was a bumper off job, I know to change the bulbs you can access the rear of the unit by pulling back the wheel arch liner but not sure if there is enough room to get to the retaining screws. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
iantt Posted July 12, 2016 Share Posted July 12, 2016 to remove the lamp assy, you need to just remove the front undertray/trim (19screws/bolts and 4 clips) then 2 bolts/screws hold lamp in Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted July 12, 2016 Share Posted July 12, 2016 I think I know the units Beethoven is planning and I'm very tempted myself! Are you getting the units with integrated turn signal? I think that's what I would go for, have to start saving/hiding my money from SWMBO Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
beethoven Posted July 12, 2016 Author Share Posted July 12, 2016 4 hours ago, Jonro2009 said: I think I know the units Beethoven is planning and I'm very tempted myself! Are you getting the units with integrated turn signal? I think that's what I would go for, have to start saving/hiding my money from SWMBO Sent from my iPad using Tapatalk No, you're wrong I just want to change the bulbs into LED-bulbs. So, no I am not getting the units with integrated turn signal Would be nice, though, but I don't think it is allowed in Belgium (MOT) BTW:I have turn signals in the mirrors Quote Link to comment Share on other sites More sharing options...
beethoven Posted July 12, 2016 Author Share Posted July 12, 2016 5 hours ago, iantt said: to remove the lamp assy, you need to just remove the front undertray/trim (19screws/bolts and 4 clips) then 2 bolts/screws hold lamp in Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted July 13, 2016 Share Posted July 13, 2016 Ah I see, I didn't realise it was illegal why is that? I have turn signals in the mirrors too but if I was going to change the whole unit then I would get the ones with integrated indicators. To just swap out the bulbs I believe you can access these by removing the pins in the wheel arch liner, wheel at full lock and peel the liner back. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
beethoven Posted July 13, 2016 Author Share Posted July 13, 2016 3 hours ago, Jonro2009 said: Ah I see, I didn't realise it was illegal why is that? Regulations.......I guess. I could ask,though, but I'm afraid they say no. Just like lowering springs, drilled&grooved brake disks, more powerfull calipers.(bigger disks).......it all increases the safety of the car, but in Belgium, they say NO, not without certificates, if you want changes, you'll pay for it, extra expensive MOT etc..... For example in Holland, none of all this is necessary Belgium........lousy country Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted July 13, 2016 Share Posted July 13, 2016 I had no idea about any of this, seems like madness Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
beethoven Posted July 18, 2016 Author Share Posted July 18, 2016 Arrived today:, my LED Bulbs for the front foglights 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted October 17, 2016 Share Posted October 17, 2016 Bump Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Henriii Posted June 5, 2019 Share Posted June 5, 2019 How the Fog lieghts LED working for you? Are they brighter? Can you see more with them? Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted June 10, 2019 Share Posted June 10, 2019 On 6/5/2019 at 5:42 PM, Henriii said: How the Fog lieghts LED working for you? Are they brighter? Can you see more with them? Unless an LED bulb is fitted to a lens/unit designed for LED the "throw" or effective light output i.e. how much you can see will likely be less than halogen, on the flip side oncoming drivers will get to see your nice bright LEDs and see how cool they look! 😀 Quote Link to comment Share on other sites More sharing options...
