Craig hannah Posted August 2, 2016 Share Posted August 2, 2016 Hi all driving a 2013 focus 1.0 ecoboost zetec s about 4 months ago I had the car serviced and m.o.t about a month ago the brake fluid low warning light came on drove it and it's disappeared although now whenever I'm driving the car it come on nearly every day I have checked everything that should be checked. Does anyone else have the same issue or is this a fault anyone knows of? Thanks Quote Link to comment Share on other sites More sharing options...
dezwez Posted August 2, 2016 Share Posted August 2, 2016 you may have a leak somewhere Quote Link to comment Share on other sites More sharing options...
m1tch Posted August 3, 2016 Share Posted August 3, 2016 10 hours ago, Craig hannah said: Hi all driving a 2013 focus 1.0 ecoboost zetec s about 4 months ago I had the car serviced and m.o.t about a month ago the brake fluid low warning light came on drove it and it's disappeared although now whenever I'm driving the car it come on nearly every day I have checked everything that should be checked. Does anyone else have the same issue or is this a fault anyone knows of? Thanks I am guessing you have topped up the fluid now? The previous owner might have change the brake pads and bled the lines but not topped up the fluid enough - perhaps also check the connector on the master in case its loose. Quote Link to comment Share on other sites More sharing options...
