dobrojoe Posted August 6, 2016 Share Posted August 6, 2016 I know how to do the parallel assisted park using the button on the console and indicators but I haven't found how to initiate a 'reversing into a supermarket bay' situation and I can find anything about it in the manual. I emailed Ford Customer Services with the question and they unhelpfully referred me to a dealer. I emailed the dealer twice and got no reply. TIA Quote Link to comment Share on other sites More sharing options...
MarksST Posted August 6, 2016 Share Posted August 6, 2016 If it's not in the manual it probably isn't possible, well not by the car you should be able to use other controls to perform this manoeuvre. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2016 Share Posted August 6, 2016 In my Focus, I just push the auto park button twice and on the screen it shows that you are trying for a parking bay space... My auto park is a button next to the gear stick above the heated steering wheel button (if you have that) Hope that helps Quote Link to comment Share on other sites More sharing options...
dobrojoe Posted August 6, 2016 Author Share Posted August 6, 2016 JImbobcook. That's what I thought it was. The dealer demonstrated this to me when the car was handed over but it hasn't worked for me since. I went out and tried it just now, slow presses, fast presses it is either asking me if I want to pull out to the left or right, or goes back to the default screen. Should I reboot Sync? The dealer had to do this once already because the maps were not displaying. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2016 Share Posted August 6, 2016 1 minute ago, dobrojoe said: JImbobcook. That's what I thought it was. The dealer demonstrated this to me when the car was handed over but it hasn't worked for me since. I went out and tried it just now, slow presses, fast presses it is either asking me if I want to pull out to the left or right, or goes back to the default screen. Should I reboot Sync? The dealer had to do this once already because the maps were not displaying. So you are driving below 10mph and you press the button once then again and for you it changes if you are looking on the left or right? Mine only lets me go left and has Parallel or perpendicular (if that's the right word) parking... If you are stopped and you are pushing the button does it not already think you are parked and wants to know which way you want to leave the space as it will get you out of the space also I think... Quote Link to comment Share on other sites More sharing options...
dobrojoe Posted August 6, 2016 Author Share Posted August 6, 2016 37 minutes ago, MarksST said: If it's not in the manual it probably isn't possible, well not by the car you should be able to use other controls to perform this manoeuvre. I've found several things not covered by the manual, and lots of stuff that is irrelevant. I have complained to Ford about their manuals. You would think that when you spend over 20K on a car, they could at least provide a relevant manual. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 6, 2016 Share Posted August 6, 2016 did the dealer show you both parking function, parallel and perpendicular? what does it show on the screen when you push button? Quote Link to comment Share on other sites More sharing options...
TitXlover Posted August 6, 2016 Share Posted August 6, 2016 (edited) On my Focus there are 2 buttons, with a P and a symbol next to it. I think from memory, the left one is park and the right one takes you out of the space. It defaults to park on the passenger side, if you want to park on driver's side you have to use the indicator too. I think it should detect if you need parallel or perpendicular park, I have only used parallel park but found it works well. Edited August 6, 2016 by TitXlover Correction. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2016 Share Posted August 6, 2016 1 minute ago, TitXlover said: On my Focus there are 2 buttons, with a P and a symbol next to it. I think the left one is parallel and perpendicular is the right one. It defaults to park on the passenger side, if you want to park on driver's side you have to use the indicator too. I have only used parallel park but found it works well. Yeah it's great watching the fear on peoples faces in the car haha Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted August 6, 2016 Share Posted August 6, 2016 The two P buttons have two different functions. One turns the parking sensors on and off, the other does the parallel/perpendicular parking. If its saying left or right only, try holding the button down to clear it. If I recall I had mine stuck in self-park for a while every time I started and reversed the car and that cleared and reset it for me. Quote Link to comment Share on other sites More sharing options...
dobrojoe Posted August 6, 2016 Author Share Posted August 6, 2016 2 hours ago, jimbobcook said: Yeah it's great watching the fear on peoples faces in the car haha I have only tried it a few times. It works 80% of the time but it is not totally reliable if you are parking on a curved road or if the vehicles in front and behind are not parked straight you can end up too close or too far from the kerb. Quote Link to comment Share on other sites More sharing options...
dobrojoe Posted August 6, 2016 Author Share Posted August 6, 2016 2 hours ago, iantt said: did the dealer show you both parking function, parallel and perpendicular? what does it show on the screen when you push button? Yes, the dealer showed me both but he was showing me so much stuff within the space of a few minutes, I couldn't take it all in. If I give the button a double press, it returns to the home screen. I am trying to reverse into my driveway and into a car port missing the flower planters. Maybe I'm asking too much? Quote Link to comment Share on other sites More sharing options...
