Goldfazer Posted August 6, 2016 Share Posted August 6, 2016 As the title - the beeps have suddenly gone so quiet I can hardly hear them! Any ideas what to check? Cheers. Focus CC-3 2.0TDCi '08 Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2016 Share Posted August 6, 2016 Can you control the beeps level with the volume up and down when they are going off? I know you can obviously change the prompt volume from the Sat nav and audio as they are saying something... Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted August 6, 2016 Share Posted August 6, 2016 Check your fuse! Do your reverse lights work? Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Cheers, I'll check the lights/fuse. Not sure about the vol control - I'll check. Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Rev lights OK, vol control doesn't do anything. Where is the beeper - just in case it's got a birds nest on it or summat :) Quote Link to comment Share on other sites More sharing options...
Micro Posted August 6, 2016 Share Posted August 6, 2016 Are yours an aftermarket addon? If so, generally they'll be near the back if there is no display. The big rear loom appears to be on the passenger side of the boot behind the trim. Alternatively - turn your ignition to pos II (engine not running), put car in reverse, and follow the (quiet) beeps. Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Pretty sure they're oem. But I could be wrong! No visual aid though. I'll take the trim of when the Olympic cycling's finished or I need a stretch :) Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Sounds like it's behind the driver's side rear seat side trim. Haynes doesn't say how to remove it for the CC so will see what happens Quote Link to comment Share on other sites More sharing options...
iantt Posted August 6, 2016 Share Posted August 6, 2016 your right, behind the o/s rear quarter panel trim , its above the audio speaker Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Cheers - no need to remove the seat then? Just work out how the trim comes off? Quote Link to comment Share on other sites More sharing options...
iantt Posted August 6, 2016 Share Posted August 6, 2016 oh yes you need to remove seat base and seat backs, trim behind seats , lower trims etc Quote Link to comment Share on other sites More sharing options...
Goldfazer Posted August 6, 2016 Author Share Posted August 6, 2016 Bugger! How do the seats come off? They're bolted on somehow. And Google has failed dismally :) Quote Link to comment Share on other sites More sharing options...
iantt Posted August 6, 2016 Share Posted August 6, 2016 and head rest, head rest tubes , sill trim. Quote Link to comment Share on other sites More sharing options...
