Patrico777 Posted August 15, 2016 Share Posted August 15, 2016 Hi My exhaust the tip on my st150 is so dark and dirty does not look nice would metal polish be the solution with the wire sponge ?? Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted August 15, 2016 Share Posted August 15, 2016 Try it, just don't scratch it. Sent from my iPad using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Fezza_luke1.6 Posted August 15, 2016 Share Posted August 15, 2016 Any thought on a performance exhaust system for my 1.6 tdci zetec s? New to this! Quote Link to comment Share on other sites More sharing options...
laumk7 Posted August 15, 2016 Share Posted August 15, 2016 I think unless the soot is caked on you'll be alright with a soft cloth and metal polish, rather than a wire wool pad Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted August 15, 2016 Author Share Posted August 15, 2016 21 minutes ago, laumk7 said: I think unless the soot is caked on you'll be alright with a soft cloth and metal polish, rather than a wire wool pad I will give it a try Quote Link to comment Share on other sites More sharing options...
laumk7 Posted August 15, 2016 Share Posted August 15, 2016 I've bought some tcut chrome Polish from Halford (though autosol is the same apparently) for when mine needs doing if that helps at all? Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted August 15, 2016 Author Share Posted August 15, 2016 1 minute ago, laumk7 said: I've bought some tcut chrome Polish from Halford (though autosol is the same apparently) for when mine needs doing if that helps at all? I will go and buy that us well tomorrow and try it thanks Quote Link to comment Share on other sites More sharing options...
laumk7 Posted August 15, 2016 Share Posted August 15, 2016 Don't forget to get some high temperature wax on it when you've finished Tarting it up, wheel wax should do as that has to cope with high temperatures I use swissvax but at 40 odd quid for 50ml, this stuff is more reasonable. https://www.shopnshine.co.uk/finish-kare-hi-temp-paste-wax-1000p?___SID=U Quote Link to comment Share on other sites More sharing options...
Patrico777 Posted August 15, 2016 Author Share Posted August 15, 2016 1 hour ago, laumk7 said: Don't forget to get some high temperature wax on it when you've finished Tarting it up, wheel wax should do as that has to cope with high temperatures I use swissvax but at 40 odd quid for 50ml, this stuff is more reasonable. https://www.shopnshine.co.uk/finish-kare-hi-temp-paste-wax-1000p?___SID=U That just coming up to expenssive lol I try in poundland metal polish should do the job as well lol Quote Link to comment Share on other sites More sharing options...
SpannerTheCat Posted August 15, 2016 Share Posted August 15, 2016 Another thumbs up from me for Autosol,used it for ages but go gently with it after you've washed the light staining off then buff it up for best results. Quote Link to comment Share on other sites More sharing options...
m1tch Posted August 16, 2016 Share Posted August 16, 2016 6 hours ago, SpannerTheCat said: Another thumbs up from me for Autosol,used it for ages but go gently with it after you've washed the light staining off then buff it up for best results. Try Meguiers NXT metal polysh (correct spelling), I had a mate who always used Autosol, then he tried some of my Meguiers and switched. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 16, 2016 Share Posted August 16, 2016 White diamond metal polish and sealant, also very good for polishing up hazy headlamps on older cars. Quote Link to comment Share on other sites More sharing options...
JoeZS19 Posted August 17, 2016 Share Posted August 17, 2016 Ive used autosol on my exhaust and it came up well. It wasn't majorly black but had discoloured Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 17, 2016 Share Posted August 17, 2016 It's Autosol you're meant to use? Hmm, thought the Anusol wasn't having the desired effect... 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted August 17, 2016 Share Posted August 17, 2016 51 minutes ago, TomsFocus said: It's Autosol you're meant to use? Hmm, thought the Anusol wasn't having the desired effect... thats a different exhaust!! 2 Quote Link to comment Share on other sites More sharing options...
Pullock Posted August 17, 2016 Share Posted August 17, 2016 3 hours ago, TomsFocus said: It's Autosol you're meant to use? Hmm, thought the Anusol wasn't having the desired effect... 2 hours ago, iantt said: thats a different exhaust!! Plus the wrong hole! 2 Quote Link to comment Share on other sites More sharing options...
