spurswes Posted August 18, 2016 Share Posted August 18, 2016 I can't find the topic which shows how to do the dashboard test,could some shed some light plz as can't remember how to do it? Thanks Quote Link to comment Share on other sites More sharing options...
Russ Posted August 18, 2016 Share Posted August 18, 2016 Depends which car you have as the methods although similar vary slightly. Quote Link to comment Share on other sites More sharing options...
spurswes Posted August 18, 2016 Author Share Posted August 18, 2016 2 hours ago, Russ said: Depends which car you have as the methods although similar vary slightly. Focus Zetec climate 55 plate Quote Link to comment Share on other sites More sharing options...
Russ Posted August 18, 2016 Share Posted August 18, 2016 1 hour ago, spurswes said: Focus Zetec climate 55 plate Press (and keep it pressed) the end of the indicator stalk whilst turning the key till your dash lights up. (Don't start the car) keep the stalk pressed for approx 10 seconds and it should come up 'test' on your dashboard. Each press of the stalk will go one step through the tests. 1 Quote Link to comment Share on other sites More sharing options...
spurswes Posted August 18, 2016 Author Share Posted August 18, 2016 21 minutes ago, Russ said: Press (and keep it pressed) the end of the indicator stalk whilst turning the key till your dash lights up. (Don't start the car) keep the stalk pressed for approx 10 seconds and it should come up 'test' on your dashboard. Each press of the stalk will go one step through the tests. Thanks so much Russ 1 Quote Link to comment Share on other sites More sharing options...
