Idle problem
dfoord
 Share
Hello clever people
my focus has developed an annoying flutter or judder while idling ???
when car is warm and I stop at lights or to turn etc etc it judders slightly needle hardly moves and it doesn't feel like it's going to konk out or anything but it is annoying
sometimes the needle does move while it judders???
car drives fine otherwise
any ideas ? Before I let a garage loose on it
thanks for looking
Link to comment
Just to mention that it's been like it for a couple of months now
and today after a long drive back from Hastings I noticed that if I timed it right and pulled away just as it juddered it struggle to accelerate for a second ?
Link to comment
garage said they can't fit me in just yet grrrr
but said its got a misfire and shouldn't be too bad ??
i drove it today and it kept stalling when revs got too low
Link to comment
A misfire is most likely to be ignition: Plugs, HT leads, Coil pack.
Another common cause of uneven idle is the throttle body. Also a range of fuel problems could cause it.
It will need some careful & experienced diagnosis to determine the cause. They should first look for diagnostic codes (DTCs), then if none are found, start with plugs & leads. Sometimes if no DTCs are present, it is best to wait (if the symptoms are not severe) until DTCs appear, rather than changing expensive bits on a semi-random basis.
Link to comment
Thanks for all your help people it's sorted
the garage could not fit me in and gave the game away by saying it shouldn't be a problem as I never had plugs changed on last service
so (ting light bulb) went to Halfords got a set of Bosch plugs and I changed them it's now running sweeeeeeet
one of of the old plugs just fell apart when I took it out
so thanks again people I'm well chuffed
  • Like 1
Link to comment
On ‎22‎/‎08‎/‎2016 at 7:26 PM, dfoord said:
It's a 2.0 automatic 2008 titanium duratec petrol
had a service and mot 2 weeks ago
no codes or light on dash
it was obviously just an oil service then, did you get charged for a full one?
Link to comment
hello ippy
they call it a silver service which includes a lot of checks oil and filter change and they only do plugs with the gold one
so i was lucky the guy mentioned it misfiring cos i had no idea as it drove quite well
i know they charge about £75 for labour and then the cost of plugs are £30 PHEW
so im glad i did it myself
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
