chris1200 Posted September 1, 2016 Share Posted September 1, 2016 .....for a 2007 Mondeo mk3. I have the 6000CD unit but it doesn't have bluetooth for handsfree calls so if anyone has a good and perfectly working Sony one available with bluetooth please let me know. Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 1, 2016 Share Posted September 1, 2016 The bluetooth is a seperate module and not part of the radio. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Ken.K Posted September 1, 2016 Share Posted September 1, 2016 .....for a 2007 Mondeo mk3. I have the 6000CD unit but it doesn't have bluetooth for handsfree calls so if anyone has a good and perfectly working Sony one available with bluetooth please let me know. Thanks Get an aftermarket one like eonon or pioneer. Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMX Posted September 1, 2016 Share Posted September 1, 2016 6 hours ago, Ken.K said: Get an aftermarket one like eonon or pioneer. or Zenec Quote Link to comment Share on other sites More sharing options...
chris1200 Posted September 1, 2016 Author Share Posted September 1, 2016 OK then, a bluetooth module for the existing CD6000..........are they easy to fit, where can I get one. I'd rather keep the one I have without the hassle of a new one that may or may not fit or look right. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 1, 2016 Share Posted September 1, 2016 You need the correct module, microphone and all the correct loom which are all expensive and hard to locate. If you are determined to retain the original HU then I suggest a Parrot kit. The MKi9100 is an excellent system. Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
Ken.K Posted September 2, 2016 Share Posted September 2, 2016 17 hours ago, Stoney871 said: You need the correct module, microphone and all the correct loom which are all expensive and hard to locate. If you are determined to retain the original HU then I suggest a Parrot kit. The MKi9100 is an excellent system. Sent from my SM-G930F this looks like a very good kit may just get one myself as it seems to solve all my troubles. quick question though does it work with the steering wheel control Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 2, 2016 Share Posted September 2, 2016 The bluetooth controls are all via the Parrot system. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Lenny Posted September 2, 2016 Share Posted September 2, 2016 2 hours ago, Ken.K said: this looks like a very good kit may just get one myself as it seems to solve all my troubles. quick question though does it work with the steering wheel control The mki9100 and mki9200 Parrott kits are leading edge technology from a company owned by Nokia, The control unit supplied is wireless so it can be stuck anywhere for factory appearance including mounting to steering wheel. Mki9100👇 Mki9200👇The only additional items required to be purchased along with the chosen kit are; a model specific SOT cable adaptor link: http://www.ebay.co.uk/itm/SOT-092S-FORD-Mondeo-Parrot-Bluetooth-ISO-Adaptor-Lead-/250562436434?hash=item3a56af5d52:g:alUAAOxyjxlTNrXw and a piggy back fuse adaptor; for use when sourcing an ignition live feed makes it easier as it fits to an existing ignition live source in the passenger fuse board such as the horn fuse or reverse light fuse supply. large fuse size: http://www.ebay.co.uk/itm/Add-A-Circuit-Fuse-Tap-Piggy-Back-Standard-Blade-Fuse-Holder-ATO-ATC-12v-24v-/180735526749?hash=item2a14ad475d:m:mgwdjrqZXwu16DdAcU69z7A small fuse size: http://www.ebay.co.uk/itm/Add-Circuit-Fuse-Tap-Piggy-Back-MINI-Blade-Fuse-Holder-ATM-APM-12v-24v-12-volt-/180735820543 Quote Link to comment Share on other sites More sharing options...
