Please can someone help
walesbluebird
 Share
If you have the direction set to windscreen the air con will automatically come on, change the air flow direction knob to a different setting and the air conditioning won't come on unless you turn it on manually.
  • Like 5
Link to comment
thats what i was trying to say lol
  • Like 2
Link to comment
6 hours ago, walesbluebird said:
thank you I will give that ago
Reply back here if it still does not work, perhaps with a bit more info.
I see it says Titanium, does that have the climate control option?
And does the light that indicates a/c on light up, or is it that you can hear / see / feel it running ?
Link to comment
A very good point Peter, if it has climate control then it is very different and usually there is an Eco switch that allows use of blowers without air con. Climate control is designed to use aircon all the time to keep the car at the temp you set it at, so if it has climate control then it is normal to be on all the time unless you switch it to eco mode.
Varies a bit from make to make but they all work pretty much the same way, whether air con or actual climate control.
  • Like 1
Link to comment
3 hours ago, walesbluebird said:
it does not have the climate control option
and yes I can hear / see / feel it running
If it is running when the a/c light (above the a/c button) is out, then the fault almost has to be either: a/c relay (R11 in the engine bay junction box) is jammed on, a/c clutch is jammed on, or pcm faulty. Pull out the relay R11 to test.
If the a/c light remains lit, despite pressing the a/c on/off button, then the fault is in the button, its wiring to the GEM / BCM, or in the GEM itself. There is a GEM test mode, by holding in the rear window de-mister button while turning the igntion on. Then all GEM inputs (like door opening & indicators & a/c button) will sound a chime when activated.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
