Another Wind Deflector Thread...
TomsFocus
 Share
Lol, I know there seems to be loads of these atm!
But not this question.  Basically I don't have any local friends to help put the window up when I fit the Heko's to the Mk2.5.  Is there any way to get around that and stop it bouncing back?  And do they need the clips on the Mk2.5 or can I get away without?  Maybe use some extra adhesive, I was advised silicone on facebook?
Swapping engines doesn't phase me but I've never fitted deflectors before! :laugh:
Cheers
Tom
Link to comment
i fitted team heko's by myself last week it was a bit fiddily and i had the problem of the window coming back down it worked after i put the clips in and then slowly raised the window back up to the clips it bounced back a couple times but it now goes back up automatically with no problems. hope this helped
Link to comment
cant help you there mate. i dont have power fold mirrors, just thinking about it could you hold the deflectors where they would fit but not put them in so you can move them quickly if they go to hit them and activate the mirrors or have them closed and try to fit them that way. just a thought i had.
  • Like 1
Link to comment
Cheers
Tom
This youtube video may help you.
Link to comment
yes , fitting the deflectors is only a 1 man job
no , your wing mirrors will not hit the deflectors when folded
yes , they will stay in place without using the metal clips ( which were way too big anyway to fit in the window recess on the set i purchased ) - use additional tape / sealant if not using clips
close windows gradually , bit by bit , until fully pushed into place. - should be no drama with the window pressure sensor.
  • Like 1
Link to comment
oh , and leave the windows closed for at least 12 hours after fitting , gives the window seals time to form into a new shape that fits around the deflector.........
:-D
Link to comment
Deflectors fitted this afternoon.  Didn't have any window issues after all!
Fronts are solid with extra double sided tape but I'm pretty sure the rears won't stay in though lol, I don't open the rear windows often but I'll just have to fit the clips if they do fall out.
Link to comment
I had issues with my rear Hekos. No more nails tape and windows closed for 24 hours and they seem pretty solid in there now with windows open at 60 (whereas before they would slip slightly with the windows closed).
Sent from my Nexus 6P using Tapatalk
Link to comment
They wouldn't even hold in place on their own while I put the window up, the gap seems a lot bigger on the back, but it might just be because they don't have the 'L' shape that fronts do.  Now going out so will see if they've stuck at all lol...
Link to comment
i only bought the front window kit , wasnt that bothered about the rear deflectors
back seat passengers can stick their heads out the window for all i care.........  ;-)
Link to comment
The rear ones cost an extra pound, for that I wasn't bothered if they fell out lol.
They will need the clips though so that's a job for tomorrow.  Fronts have stuck well but both windows bounce.  Do I just have to wait for them to bed in to stop that?
Link to comment
mine did that but how i stopped that was i put clips in the front and then nudged the window back up not auto so it can slowly go into the clips it bounced a few times but couple times doing that it stopped and now goes up without problems
Link to comment
When I installed my heko's I did so with the windows closed. Easy it was as you have the glass to guide you in. Lowered glass and raised it a few times on each window with out any issue.
I then removed the heko's removed the protective film and the backing off the sticky tape, then popped them back in with the windows closed again.
There was no need for the clips.
Link to comment
Mine didn't come with protective film, nearside one arrived with a few scratches. :sad:
Anyway, fitting the clips has worked on 3 windows, just one still keeps bouncing...the drivers one! :rolleyes:. I can't even see what the issue is, it has broken at the top corner, must be me putting it in but dont see why that should stop it, if anything it give it more room.
Link to comment
So the drivers went up fine once this afternoon, assumed it was sorted...  But bounced every time since.
I also didn't think about how thick they make the a pillar, junction and roubdabout visibility on the driver's side is reduced a fair bit.
And i can see the clip which is irritating.
I have a feeling they won't be staying in long...  I should really stop buying mods!!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
