Satnav retrofit help
I'm retrofitting a satnav to my 2015 Titanium X and slowly working it out but need a bit of help with a few things.
The KM issue has been mentioned on Facebook a fair bit and wondered if that's easy to sort?
I have a reversing camera at the moment. The SatNav unit won't show a picture when in reverse. I just thought it was a case of activating it but I've read the green connection on the back is the camera connection which I don't have.
Hi
I have the same spec fiesta as you and the Rev camera connections are in the large black plug that has a latch so if they are run into that 4 pin green plug you'll need to get some screened cable and connect on to them and run them into that green connector.
i did have the pin outs for the Rev camera written down as I had to work them out when I fitted my Alpine unit.
I done this by stripping the boot and following the cable run to a plug on the NS / C post and then jus buzzed them out from there. If it will help I can dig them out tomorrow night.
Regards karl
That would be great 😆
Strange how the original setup uses the large black plug connection for the camera but the satnav doesn't.
I came across a connector on the net that would possibly fit
How did you overcome the KM to miles issue? I've gone into the setting but found it was already set to english and won't select miles on the menu.
Camera connector now sourced so just need to work out where the camera cables are on the loom.
  • 4 months later...
Hi
has anything happened regarding this mod
on the screen photo above what are all the other connectors for
is there one for the gps antenna
  • 4 months later...
GPS is the blue fakra cable unless you have this in your car already you can buy the GPS receiver on eBay for around £6 and that works fine
the issue with the reverse camera is the camera itself has to be ntsc format not pal otherwise it will not respond to the satnav display and you can use the lead in the pic above to connect it unless you have the loom already in car. The black fakra socket on the back of satnav uses the black connector of the back of your stereo unit then you run another fakra lead from the pink connector of your satnav to the black socket on the stereo unit so you can receive dab and radio
then you attach 2 wires from pin 6 and 12 of your display plug to pin 4 and 5 on your head unit for nav voice hope it helps
  • 5 months later...
Hi
have just come over from the dark (vauxhall) side. I have a Fiesta 2014 Titanium X and have read the sat nav thread with interest and wondered how you over come the Km to miles issue ?
any help would be great
1 hour ago, Coldhands said:
Hi
you need to use forscan to change the screen size to 5 MFD then it will let you change back to miles if you dont then your stuck with KM.
thanks for that info, could you help with the relevant menu's to look in
thanks in advance
  • 3 months later...
@Willy Did you figure out which wire on the original loom that you needed to add the connector to? And did you just cut the wire and solder the connector to the wire or did you do something else
I am retrofitting sat nav at the moment at have the same issue that you had :)
Thank you in advance
Brgds
Simon
Sorry mate but never finished it and sold the unit abroad.
