thor1 Posted September 13, 2016 Share Posted September 13, 2016 I got focus Mk 3.5 indicator light. fitting has been damaged, can some give me clues how to replace. thanks Quote Link to comment Share on other sites More sharing options...
andypsp Posted September 13, 2016 Share Posted September 13, 2016 if it`s the one on the wing mirror and the clear plastic cover has broke they are avalible online Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 13, 2016 Share Posted September 13, 2016 Easy to do. Adjust the mirror glass down and inwards as far as it will go. Inside the casings at the top you will see small semi-circular notches with lugs clipped into them. Use two small screwdrivers (or similar inplements) to push both of the lugs down at the same time and pull the mirror caps backwards and off. The indicator lenses are held in place with a lug at the thick end and a P shaped clip a third of the way down from the narrow end. Use a small flat screwdriver to lever at the narrow end and the lenses will pop out easily. The bulb holders are an easy push/pull fit. Refit in reverse ensuring that the mirror caps are seated in the housing properly before clipping the top lugs back in place. Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted September 13, 2016 Share Posted September 13, 2016 As above. Quote Link to comment Share on other sites More sharing options...
thor1 Posted September 13, 2016 Author Share Posted September 13, 2016 thanks for all the info, are they all the same for 2015 models Quote Link to comment Share on other sites More sharing options...
