greggp
Power Steering Malfunction (1.8 duratec mk2.5)
Got in car today, turned ignition and got the audio chime (when fuel is low) followed by  dash warning "power steering malfunction"  message .
Turned ignition off and on and no warnings this time?
I note from the manual that the 1.8 duratec petrol says no checks are required to power steering levels....so I'm guessing its electric system?
Drove fine to and from work no issues.
Maybe a computer glitch?  Will keep an eye on it.
Model 2008 facelift 1.8 duratec petrol titanium
Mine started to do that intermittently when the alternator and battery were on the way out.  If the ECU doesn't think that any electrical system i.e. ESP, PAS etc isn't getting sufficient power it will disable it rather than have the system fail to function correctly whilst driving.
It might just have been a one of glitch but it might be worth getting your alternator and battery tested (you can use the dashboard trick to check the alternator output).
Done the dash trick.
battery is 11.8v without engine running, 13.8v with engine running.
Scrolling thru menu I did find this
DTC #01 D900
Not sure if this is a fault code of somekind and/or related to yesterday?
Nice one.
Also to test the alternator you need to put some load on it i.e. front and back heated screens on (if you have both), all lights internal and external on, a/c on with the engine running.  The smartcharge system should keep the reading around 13.8-14v if memory serves me correctly.
Before I replaced the alternator, running this test dropped the voltage to 11.5v with the engine running :angry:
2 hours ago, 1979Damian said:
Nice on.
Yeah just tried it under load as you suggested and the voltage dropped to 11.6v at lowest. Fluctuated between this and 12v whilst under a full load.
Load used at same time as below:-
Heated front & rear screens
Front headlamps full beam
Front & rear fogs
All interior lighting
Air conditioning on full
Front Wipers on max
In experience at least, that kind of behaviour was a symptom of the alternator being on it's way out (it didn't help that the alternator had been trying to charge the original 10 year old Motorcraft battery).
If it's only done it once then it might just be a glitch and you'll probably be fine driving it, although if it does it again it might be time to start looking at solutions.  (you don't want to be going round a corner and have the ECU decide the PAS isn't getting enough juice and turn if off) :wallbash:
Thanks.  Yeah will keep an eye on it.
  Only 75 emoji are allowed.
